7 members (John V6, How, DCH, MartinB60, IcePack, Luddite, TBM), 362 guests, and 42 robots.
+8Rich 92
Posts837,279
Page 8 of 17 1 2 6 7 8 9 10 16 17
Thank you too Peter. My wife tells me that trying to follow me through roundabouts show very little roll-she tells me it appears to corner flat. And she always amazed at how fast she has to drive to catch up even though I have a strict self imposed speed limit. I'll look forward to the conversion in due course.
DaveW has skills the rest of us mortals can only dream or wish for! smile
Actually I think you'll find it's Mrs W who has the gaiter-making skills... wink
Lecat Offline OP
Finally I found the time to fit my SUPLEX kit. Fantastic result - I couldn't even tell if it was a pence or a 10 crown coin (Swedish) I was running over. laugh2
Except fitting the kit including springs, Bilstein dampers and the roller bearings I have adjusted the steering rack, fitted new Vesconite bushings (press fit and reamed), new adjustable dampers in the back. I left out the damper blades and have a slight shimmy around 50 mph to work on.
The car is a lot more controllable and has very little kick back and keeps the desired line easily. At higher speeds one can feel the dampers and springs really working in harmony and at lower speeds everything is just a lot softer but still quite firm (as it should be). My rack-and-pinion is very direct and I will fit a steering damper later to help controlling fast straight line driving. Maybe a little less toe in will help also.
All-in-all I think the SUPLEX kit makes the steering, springing and damping work better together. The whole car feel more harmonious.
Thank you all for your input in this thread cheers
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Glad to hear that you like it. Your expereiences seem to be pretty much the same as those of everyone else who has fitted the kit.
My Suplex system now has about 1,000O km and I am now so used to it that I don't even think about it. On Sunday I did a longish run with swmboJnr. as co-pilot. The roads varied from superb to terrible and at various moments some spirited cornering was undertaken smile The front end of the car stuck to the road like it was on rails and bumps in corners did not phase it for one moment and the car corners with much less body roll than previously. Also the steering is lighter and requires less muscle on all those mountain passes. Just fantastic. drive
The more I hear about Suplex the more tempted I am to get it. The traditional handling characteristics of Morgans have their charms but they also become tiring after a while - particularly on the increasingly rough roads here in the UK.
David
2020 Roadster 3.7 Dove Grey.
My 4/4 is having it fitted next week along with new kingpins. Looking forward to seeing the results!
Jays #142271 28/06/13 09:05 AM
Great review...thanks.
Jays - look forward to hearing your views too.
Lecat Offline OP
I totally agree - especially about the steering being lighter and front end grip and stability. drive
David: This is 'the much better solution' that MMC should go for - I think.
Jays: You will not be disappointed.
Richard: Sharing is what it's all about cheers
Lecat Offline OP
I actually still notice the big change every time I drive over a coin... laugh2
Seriously: Every time I leave my garage - there is a 1,5 inch steel threshold that reminds me. cloud9
My thoughts too.
I'm also very tempted.
+8 4.8
