7 members (Bitsobrits, DCH, B3MOG, JohnHarris, Barry M, tezzer, linklaw),
346
82
Topics49,848
Posts837,404
Posts: 37 |
Hi all, does anyone out there have a Rover T16 +4 and is able to describe the ignition key or better still able to photograph it for me. I have a friend who is storing above morgan and he has lost the keys. The owner is in the states and not been to the car for 4 years and he would like to move it. I would particularly like to know if it has an immobiliser on it and a key with a transponder. It has the LED in the middle of the dash but even with a charged battery this is not flashing. If it had one originally I suspect it has been disabled. I've bypassed the original switch and have got it to fire up once and before I explore much more I thought I would check out similar year +4's first. Thanks John
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Hi John, my 97 +4 has a standard Key , the imobiliser is activated by a separate push button like that for an automated garage door
Posts: 37 |
Thanks John, so if you don't press the button the immobiliser/alarm isnot set and no flashing LED?
Posts: 28,896 Likes: 352
Posts: 28,896 Likes: 352 |
Normally yes. But they do occasionally have a mind of their own. I once couldn't get Tinkerbelle to start when at a PI in W. Sussex. engine truned over fine, but no fire. Before I flattened the battery, I switched the immobiliser on for 1 minute, then off again. Result, instant start up. So it is possible the immobiliser is causing you problems JP (nearly typed 'Eric'  ).
Posts: 37 |
Thanks Graham, It's firing up every turn of the key so wondering if it's the MAF sensor now. Enjoy the trip.
Could be the ECU mine failed
