Topics49,859
Posts837,502
Posts: 986 |
I've got some beautiful leather corners from MMC. They look great but slip off rather defeating the object!
Has anyone out there in Mogland any suggestions for a safe adhesive or other form of fixing which won't harm the paintwork?
Thanks in advance. Andy.
Laser red 4/4 Red Classic Mini Cooper Sport Audi TT 2.0 TFSI Quatro
Posts: 17 |
Use a tiny bit of silicone sealer on the inside, and it sticks. Works on mine.
Torstein
4/4 Sport
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
Silicone sealer on the inside of the bonnet works for me, might be worth considering a drainage hole especially on the rears as they may fill with water? Regards john K
1993 T16 +4 Lancia Blue.
Posts: 22,359 Likes: 353
Posts: 22,359 Likes: 353 |
I don't particularly like these corners, but would stick some electrical tape across the corner, then fix with double sided tape on that.
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
Cunning! I used a small triangle of 3mm double sided number plate tape to overcome the beading edge and it seems to be holding (mind it hasn't been that long since I decided to refit them after the cowl keeps getting churned up with rubbing)
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 986 |
Thanks everyone, some good tips.
Andy
