1 members (Bitsobrits), 292 guests, and 45 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
#113079 28/11/12 06:13 PM
From Facebook, posted my my online pal:
'All is progressing nicely with the 4/4, but not so good news on Little Nellie (the 3 wheeler!). Whilst back at RPM for it's service and a number of new parts (compensator, bevel box, rear cog, a new headlamp, oil tank and shock absorber) , their keen eyes spotted a hole and stress cracks in the chassis behind the engine, so it's back with Morgan and getting a new chassis fitted as well! Just as well it's not convertible weather right now. The drive belt is also rubbing against the rear tyre and scuffing it quite badly....has anyone else had this problem?'
spend
2011 +4 'LB' Indigo Blue, Heron trim
Saab 9-3 1.8T Sportwagon
Mike Carter #113685 02/12/12 03:46 PM
Hope it's a isolated case...
stoufy #113879 03/12/12 09:44 PM
JMD Offline
Not completely an isolated incident regarding the belt rubbing the back tyre....ours got pretty bad (ie noisy) during our 1250 mile July trip in Spain/France....was sorted under warranty with new belt/pulley/tyre etc when the bevel box was changed....has since been fine. Our 3W is around #92 and was built in April.
If you look closely, the belt is located by flanges on one side of the drive pulley and the opposite side of the driven pulley. On the driven pulley the flange is on the tyre side but the belt will touch the tyre before it can get to the flange. I suspect it is kept away from the tyre by fine adjustment of the bevel box alignment.
JMD #114007 04/12/12 05:17 PM
And for the chassis cracks ?
stoufy #114034 04/12/12 07:04 PM
Nothing that a bit of braze wouldn't sort out!
PaulJ #147103 30/07/13 03:50 PM
just coming across this as my belt has had issues with alignment and has been adjusted 4 (or 5 can't remember). i've got nasty compensator klunking/knocking at low rpms.
these are the times where i wish i was close to the factory and could have it sent over for a gutting.
grr
blake
sfmorgan.tumblr.com
Blake #147114 30/07/13 04:24 PM
Anytime you let the revs go below 2700rpm this will happen. S&S most strongly warns about lugging the engine below this. It does not a happy camper make...
Michael H #147120 30/07/13 04:43 PM
sadly this is much more than the low rpm blues that the engine doesn't like. this is something much more troubling. i subscribed to the low rpm theory at first but 5,000 miles later it's gotten worse and the car sounds awful.
b
sfmorgan.tumblr.com
blake
sfmorgan.tumblr.com
Blake #147208 31/07/13 06:42 AM
I hear you, Blake (pun not intended) - mine is getting louder as well.
It sounds like something is going to break any minute.
I still enjoy it a lot, but I wonder how wide my grin would be without the rattling and other mechanical noises.
M3W, now!!!
Blake #147214 31/07/13 06:55 AM
Such a shame you have had so many issues - you don't seem to have had much luck with your car frown2
b
sfmorgan.tumblr.com
