Topics48,364
Posts813,343
Members9,215
Posts: 1,036 |
Has anyone got a wiring loom, new or used, for a 1976 Morgan +8 with a Rover 4 speed gearbox. The alternator is a Lucas 18ACR fitted I believe from 1973 to 1976; the instrument panel as that fitted to Morgan +8s from 1968 to 1976.
Posts: 16 |
Yes got a new one would you have a phone no to contact you at?
regards Jasper
Posts: 28,428 Likes: 180
Posts: 28,428 Likes: 180 |
I would suggest, if you are going to rewire, that you bring it up to newer specs with a decent fuse box - the original from that period (as I know from the work I've just had to do on my 4/4) suffers from a serious lack of protection to various circuits / systems.
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
I would suggest, if you are going to rewire, that you bring it up to newer specs with a decent fuse box - the original from that period (as I know from the work I've just had to do on my 4/4) suffers from a serious lack of protection to various circuits / systems. +1 - mine only has four fuses for the whole car!
Richard 1976 4/4 4 Seater
I bet you have a fifth  A floating one, in the middle behind the switch panel... It's for the hazard flashers.
Very true - when I got the car took me ages to work out why the hazards were not working, it was the fuse holder (the spring had gone weak) not the fuse!
Posts: 1,036 |
Thanks Graham. I'm going for orginality so keeping the fuse box. From memories of a 1972 4/4 that I owned, my Plus Eights have relays (apart from the indicator/hazards) that I don't believe were fitted to 1970s 4/4s. It could actually do with three relays; an additional one for the headlights.
Anyway, if anyone has a loom, I'd be really interested.
Thanks and regards, David.
Posts: 1,036 |
Just a gentle reminder that I am looking for a wiring loom, new or used, for a 1976 Morgan +8 with a Rover 4 speed gearbox. The alternator is a Lucas 18ACR fitted I believe from 1973 to 1976; the instrument panel as that fitted to Morgan +8s from 1968 to 1976.
Melyvn Rutter can make one up for you....
Posts: 2,515 |
1972 4/4 2 Seater
