7 members (SteveT, Tony Quinn, Ian Wegg, TeddyAds, GBpluseight, TBM, Grumpy2), 187 guests, and 38 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,354
Christoph
Posting Desperado
Posting Desperado
Neil I will have to leave this part to you as I know very little about closed cell foam . Maybe a trimmer can give you a bit of advice .
I could take the pee by saying closed cell !! OZZY but I can'nt think one up too tired.Been out in the mog all that fresh air and I nodded off watching only fools and horses must be zonked to miss that.
Originally Posted By 1955er
[quote=Jack The Lad]They are good but remember there is no give in a solid surface as in the horse hair so if the leather is rubbed against it will scuff
Good point, JTL.
How about a layer of closed- cell foam to cushion it? Am I right in thinking that should not absorb any moisture?
cheers
Neil.
1955er Offline OP
rofl
neil.
1975 4/4 4 seater, cream over blue; Q3 Quattro; Bicycle; Walking poles.
Black Phey advertise in Miscellany but don't have a website. They are on the phone:
+44 (0)1279 870698
The rocker covers can be seen here:
http://www.gomog.com/restoration/restoration8.html
Nigel
Just looked them up in Miscellany. They have email:
blackphey@hotmail.com
1955er Offline OP
Thanks Nigel, will follow that up. thumbs
Cheers,
Neil.
1955er Offline OP
Guys,
in the end I decided to go the "traditional" approach and used closed cell foam under the leather.
This gives good firm support for this " high stress " area and is resistant to moisture.
The pic shows the old leather removed and demonstrates just what a harsh environment that is down there at the junction of the chassis and floor!
The leather had obviously become wet and then dried, ( probably on more than one occasion ), shrinking as it did so, pulling away from the floor where it had been tacked down. ( straight horizontal line denotes chassis/floor line angle )
The worst area is just forward of the chassis cross member (probably related to water ingress down the leading edge of the door). The leather here was as fragile as parchment!
As always, thanks for all suggestions.
cheers
Neil.
Posting Desperado
Posting Desperado
If the sun does that to the leather what does it do to your skin . ooo You need a bit of this snow
Posting Desperado
Posting Desperado
I had a look at these a couple of weeks ago fitted by the owner they scratch and mark very easy , he had not covered them with leather .
But the owner was not at all bothered.
Good point, JTL.
cheers
Neil. [/quote]
