4 members (Soleng, John Winn, TBM, JohnMat), 246 guests, and 44 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,341
Christoph
Page 3 of 8 1 2 3 4 5 6 7 8
Saw the newest Melvyn Rutter catalog at tonights club meeting and he offers a turned dash for the 3 wheeler.
Charlie, Former Editor
I tried and failed to change my SW x 180 - what am I doing wrong?
am sure this is easy - but would value some advice! when i tried it seemed as if I would have to dismantle the Boss - and that did not seem right!!
what should I do? An idiots guide please!! confused2
Neil
You could re-drill the boss but there are two splined joints in the steering column so there is a lot of scope for spinning the whole column round complete with the wheel.
Hi m3boy
I drilled 3 new holes in the steering wheel so now I have 6 bolts in it. 3 to hold the boss on and 3 dummies.
If I knew how to put photos on here I'd post a few.
Thanks DofO - that helps - thought i was going barmy - well maybe I am!!!! cheers
Neil
FYI Allon White won't do a recover of the steering column cover via mail - he needs the car in shop...too bad...
1965 Plus 4
2008 997 Turbo Cab
1981 Alfa Spider
1954 Austin Healey 100 (SOLD)
2013 M3W (SOLD)
AQM Offline
I had a look at those Mig watches. Am I the only one thinking this is not a councours (spl?) vehicle, and that it may be quite a bit of work getting one refinished etc. before it's useable (i.e. pretty, basically)?
With that in mind, I found this:
From here:
http://friebe.eu/Neuheiten/Bordchronograph-Adriatica.html
And one with a simpler face from the same company:
http://friebe.eu/Bordinstrumente-und-Zubehoer/Borduhren/Borduhr-Adriatica.html (sorry can't image-link to their pics)
And the Benz-Micro, which apparently are the replacement for several helicopter outfits for the old mechanical clocks:
And a more rendered Benz-Micro:
Advantage of the newer quarts version (apart from still looking good, imo), is this:
Quote:
The quartz clock is quite flat, so it does not screw into a standard 57mm opening, but is screwed onto the panel, protruding only a few millimeters.
From this helicopter clock-thread:
http://forums.watchuseek.com/f7/helicopter-clocks-look-behind-scenes-272627.html
Anyway, those black ones wouldn't look amiss in the cockpit of the M3W, I think. And as they don't need a lot of depth, you have more choice as to placement.
HJP Offline
Thanks AQM , I rather like them , the fact that they can be surface mounted is a big advantage .
Hugh
Nice AQM...
I too was looking at some of the MIG clocks on Ebay, and I came to the conclusion that:
1) I'd have to fabricate a center pod below the stock gauges or drill a HUGE hole in the passenger dash to get one to fit.
2) The quality and finish of these finely crafted pieces of Soviet hardware was perhaps a bit questionable.
3) That it just wasn't worth it...
I love the way they are installed and integrated into some of the custom 4Wer dashes posted above, but I don't think you can easily add the MIG clock to the existing dash without it looking tacked on...
The clocks you have listed seem like a much better looking, easier option for those looking for a bit of customization.
I have no doubt that Blake will get around to finding someone to build him a replacement dash, maybe MK or Pete Larsen, eventually! I'm willing to start a pool here on TM taking bets on which piece of his car gets massaged next!
1965 Plus 4
2008 997 Turbo Cab
1981 Alfa Spider
2013 M3W (SOLD)
The Benz Micros are rather nice and very apt styling for the Three Wheeler. I've got a MIG clock on its way from the Ukraine at the moment for my 4/4 but I'll have to make a complete new dash to fit it into.....a nice winter project!
