3 members (jejemek, Craig Jezz, Robbie), 314 guests, and 95 robots.
Topics49,846
Posts837,383
Page 14 of 17 1 2 12 13 14 15 16 17
#149189 13/08/13 05:59 AM
If you are going to Vesconite, make sure it's the 'Hi Lube' variety - as you are no doubt aware with your engineering background, there are various grades smile
Cheers,
#149216 13/08/13 07:51 AM
Lecat Offline OP
Originally Posted By Mike Hughes
I do take David's point though, on reasonable roads the car is fine.Unfortunately on the typical B roads in my area I find the car is limited by it's suspension performance and is not so enjoyable, particularly for the passenger..
I agree that the original suspension is fine on reasonable roads and that the passenger (often swmbo in my case) suffers more. I'm glad my swmbo had the chance to feel the stiffness of the original setup as she now can really enjoy the Suplex conversion as much as I do.
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
#149225 13/08/13 08:24 AM
Heard of them.
Vesconite were the ones the factory fitted.
#149581 14/08/13 07:15 PM
E
E
Railko make a swivel pin bush conversion for Series Land Rovers. Quite a popular conversion as it tends to damp the steering better.
I'm still trying to discover what (polymer) Vesconite actually is, I have a feeling its Polyamide (Nylon) but I think the company claim its not. sherlock
1989 911 Porsche Carrera
Land Rover Series
Defender 90 SW
AQM Offline
It's polyester:
Quote:
Vesconite being a thermoplastic polyester based product is a particularly safe product to handle. It does not contain any asbestos or other dangerous fillers
From here:
http://www.vesco.com.au/safety/
As they say, Nylon is hydroscopic. Their product, if polyester, is not (well not the same degree):
http://www.vesconite.com/prod/hilube.htm (notice how it says "VescoPlastics:" on the tab above the URL, so I can only assume it's the same firm/product.
AQM #149708 15/08/13 10:14 AM
E
E
Interesting, I did think it may be PET but I could find no reference on the Vesconite (South Africa) website and I dont think they mention the polymer type or CAS number on their MSDS's. Obviously the Australians are more open with information smile
Land Rover Series
Defender 90 SW
AQM Offline
Yes, it seems so. In all honesty, though, I had a sneaking suspicision it was polyester before I did the search, so I simply did a Google search with both the brand name and polyester in it, and that's why I stumbled upon the Australian site.
AQM #149761 15/08/13 03:06 PM
PJB Offline
Much of this has been answered by others, thanks to them all ~ however:
1. MMC response: The first time the Morgan test drivers drove a car so fitted with the SUPLEX Refinement System (Initially referred to as a 'Comfort Pack' in the development phase) they were impressed enough to want to try it themselves. They are now working with SUPLEX on further developments.
2. Shimmy: It is of course not the SUPLEX RS kit that causes shimmy, though the loss of friction by no longer having a compressed rebound spring will further reduce the friction in the steering. It is well known that removing the friction steering damper/blades and fitting ball thrust races can result in shimmy, hence the need often in those cases for a hydraulic steering damper, like used on many modern sports cars.
3. Lack of bump travel: this is one of the reasons why the rising rate spring characteristic is so beneficial, one can still have a soft initial spring rate for ride comfort yet no crashing through on big bumps as the spring rate increases to prevent it, another Morgan suspension guru was a little mistaken previously on this point too.
4. Rebound spring. A very stiff rebound spring together with rising rate mains gives significantly increased roll stiffness with good ride. Hence the very stiff rebound spring that never goes coil bound.
5. Specific damper: Every change of spring rate, whether linear or nonlinear/rising rate needs a new damper setting up, as on ALL cars by all car companies. That is what SUPLEX did with Bilstein. Bilstein does not list a damper for Morgans as they supply their damper with the SUPLEX kit. It will not work well with other spring rates of course. High and low speed bump and rebound settings are quite unique in this Bilstein damper matched to this rising rate spring system, so other dampers from other reputable manufacturers will not work as well as the specified Bilsteins on this spring system. Hence matched springs and dampers.
6. Different weights: the system was set up for a mid weight car but has been extensively tested from 750kg up to 950 kg (unladen) with no significant change in ride. Engines from 1.6 IL4, to 3.9 V8 and 3.7 V6. The ride frequency, which is what one feels, changes by only 6% between a 850kg car and a 950 kg car, so very little noticeable difference. Also the rising rate in bump means that in roll the spring rate increases as the car starts to roll, so a heavier car settles at a higher spring rate in roll, that in this case is less than a car on stiff linear main springs.
7. Adjustable height: The threaded shrouds with spring seats are there to accommodate the range of weights of cars so that the hub's static position on the kingpin can be adjusted to just kiss the rebound spring as required.
8. The SUPLEX RS was developed by SUPLEX UK Ltd in the UK headed by Dan White, I worked as an engineering consultant and test driver during the development of the spring rate and damper settings. Something I have done of many cars, trucks and military vehicles since the 1970's for many companies.
Morgan dealers with decades of road and track experience have tried the system and recommend it, including pleasingly Librands who also market the double wishbone system so well built by Peter Mulberry.
I hope that this has helped those that have been confused or misslead, but maybe I have met 'Quicksilver' before? Best regards PJB.
PJB #149791 15/08/13 05:21 PM
A quick question - after mine was fitted I wasn't given the two C-spanners. Do I need these, for future adjustments perhaps?
Nigel
PJB #149807 15/08/13 06:12 PM
Thanks Peter for the comprehensive and informative reply. Interesting to see amongst other items that the thread title is not so far off the mark.
