2 members (JoeSpeetjens, Ian B), 321 guests, and 74 robots.
+8Rich 76
DaveW 52
Topics49,867
Posts837,614
Moggo
Page 5 of 5 1 2 3 4 5
Beamish Morgan (used to be John Macdonald racing) recommended them as beneficial to both handling and braking.
There's a reason most racing Morgan's have them!
Morgan 4/4 Sport Competition
Originally Posted By pete
Thanks Dave - think I will fpllow your lead and make my own
I have been investigating this very topic as a possible project and came across this interesting paragraph in Gomog
GoMog - Brake Reaction Bars
"It is a very simple installation. I have never seen any indication of damage to the frame through their use. One precaution is to use bolts weak enough to shear in an impact. The Mulberry and Heart of England versions are supplied with such bolts. There is another reason for this. The flexible steel frame and wooden tub of classic Morgans absorb impact forces..thereby sacrificing themselves rather than transferring that deadly force to the occupants. We do not want to add anything that can change that. It saved my life. Lorne"
Keith
Dave,
As usual great stuff. cheers
I think you have to start a Book, “Morgan workshop for dummies”
A picture say more as 100 words love
Don't Worry, Be Happy
Morgan 4/4 1985 2,0 Zetec
BMW R1200 GS
Triumph TR140
Drive on the Wild Side
Worth doing much more stable under heavy braking and having upgraded my discs to vented made quite a difference to the stability. cheers
Adrian
DaveW Offline OP
Post Photobucket reboot from September 2013.
On with the story:
I made myself some wheel stands - had some offcuts left over from the raised veg patch upgrade, and suddenly thought of the idea.They will work this way:
Or this way:
Here is the tool tray for those who haven't found it on TM:
This is the hole punched by the breather!
And it needed some repair work on the edge:
This is my fix. I've enlarged the hole. This is a soft plastic cover, a push fit, which is now painted black.
Here is one of the rusty AVO's: You can see the chafing to the lower red bush.
And here it is after some TLC:
More to follow................
And so to the axle oil. A 2 litre ice cream tub makes a great container:
This is the grease nipple on the rear u/j. Easy to get at, and don't overdo the number of pumps.
Handbrake linkage and grease nipple obvious on the sliding yoke. The u/j nipple is in the shadows. Again, all easy to get at. Gearbox remote linkage just visible above.
A better view of the front u/j grease nipple:
My fill routine - takes ages and always takes more than you expect.
There are some strong views on line as to what should be used in the BTR LSD. It's not my style to dictate what you should use. I read up on the subject and considered all the evidence. I consulted some specialists in the field and this was my choice, after careful consideration. You have to make your own mind up, as always. Last time I used semi-synth with friction modifier, but this time I had more information to hand.
Under the front wing looks quite clean. All I've done is lick over the caliper with a bit of gold paint, and touched up the black.
Note how the main spring has stayed very clean.
Some of you will recall that I had to enlarge the access hole because it did not align with the level plug. You may also recall that the heat insulation had not been cut, so despite three dealer services, the gearbox oil level had not been checked. My Dremel made short work of this.
The Getrag gearbox has a specific oil requirement, which took some finding. When I found some a few years ago, I stocked up!
My gearbox fill routine - very tight access.
And here's my replacement plug:
And that's as far as I got today.
Finally a reminder about the filter. The alternative is the Zetec filter. Note that the ST220 Mondeo filter will not fit.
(Other branded filters are available).
Oil used was Mobil 1 0/40 synthetic, after a long discussion with my tame lubrication expert about the ins and outs of various options.
Roadster mileage:
From 30th August 2008 to June 2009 2,353 miles
To September 2009 3,332 miles
To September 2010 2,161 miles
To May 2012 (MOT) 304 miles
To September 2013 2,089 miles
Apart from a few doses of grease, I didn't service the Roadster in 2012. I had all the parts in stock, but being such a washout year, mileage was so low that it didn't seem worth doing.
I'll post a clearer view on Mr Bumble's brakes after a few miles, but they were one of two immediate differences I noticed in the first hundred yards. The other was the appalling roller throttle pedal!!
The Roadster brakes need a firm shove, almost as if unservo'd, but have excellent bite once warm with a tiny amount of judder.
Final note: I've also removed two of the badges on the front, and am assembling/have assembled a similar (not quite the same) collection for Mr Bumble.
Tool Tray.............
The original is a flimsy plastic affair which has rested in my garage for the last five years.
My replacement is made of wood and screwed & glued together. It's not symmetrical because there is more room on the offside.
thumbs
