1 members (bmgermany),
93
48
Posts838,013
Posts: 60 |
Today i went out and got my first greese gun and some grease. I jacked up the car foung the nipples and cleaned off some grease from arounf the entire area. I applied the nozze, held it in place and gave a few hand pumps on the gun. The result seemed to be just a big spludge of grese around the nipple.
Is this normal, is grease actually going into the nipple, how can i check this has actually occured. How many time should i pump the gun.
Done abit of a seatch on the forums but couldnt find anything that actually explained what it sould look like and if this is normal
David
Posts: 655 Likes: 12
Posts: 655 Likes: 12 |
The grease should not come out around the nipple. Make sure that the nozzle is straight on the nipple.
Harald
Harald +4 4-seater 2008 Squadron Blue
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
Did you engage the nipple correctly. It should give a slight click as the nozzle fits over the nipple. If the suspension has been greased properly before, then 3 pumps should be more than enough. You have to make sure that no grease comes into contact with the disc brakes.
Neil
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Neil
Before you do what Neil suggests, it is worth checking that the spring-loaded ball valve at the tip of the nipple is not stuck. A gentle prod with a small Posidrive screwdriver will free it. Also make sure that the nozzle of the grease gun is square on to the nipple. Bud
Bud 4/4 "Stanley"
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
lopesd, I found the same problem when I first tried to grease my nipples, my solution was to buy a simple grease gun, not a lever operated one, and then I had no more problems. It would seem that the other gun I had bought didn't quite fit the nipples thereby giving me the same problem you seem to have.
Reg
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Knowing comes with practice. When working properly you will feel resistance at the handle. If it comes out round the edges, try a thin piece of cloth over the nipple. It will seal the edges, but the grease will still pass through in the centre.
Posts: 3,826 Likes: 69
Posts: 3,826 Likes: 69 |
Best tip I ever got was to press the tiny ballbearing with a big needle before engaging the grease gun, as Budster says. Then you will feel when the grease is going in through your hand, as Dave says. Nick
Posts: 1,502 |
What grease is recommended currently for the front suspension?
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
My choice, Castrol CL - if you can get it, (LM absorbs moisture)
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
Moly...
