3 members (Sloany, MartinB60, Hamwich), 298 guests, and 47 robots.
+8Rich 64
Adam12 62
John V6 57
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,316
Members9,215
Page 1 of 5 1 2 3 4 5
I am having a rough time tuning the carburators in my Morgan +4. I have idle going and am trying to adjust the mixture at each carburator. According to all the books you should be able to turn the jet nuts one way or the other and get an increase in speed or a falling off when you lift the needle. In the adjustment you are to take it right to the point where there is a 50 rpm increase and then a dropping off. I adjust the damn things, and there is never any increase in speed. It is very frustrating. Does anyone have any ideas what's going on?
'67 +4 tourer - broken white - RHD
It takes a little time to master the tuning of twin carbs. Screwing the jet upwards weekend the mixture, downwards to richen the mixture. Assuming your needles are correct I would wind both jets up to the weakest setting,then wind down 9 flats. Then balance the air intake and start from there. The speed increase comes when you raise the piston with the side pin. Best of luck.
Martin (Deano)
Buy this Colourtune set.
http://www.carbtune.com/colortune.html
Drive on the Wild Side
I agree with the previous screw up and back 9 flats. When I used to balance my Cooper SU's many years ago I found the best way was to put a tube to the intake and listen to the hiss and then compare with the other and then adjust the idle until they were the same. If you have not replaced the jets and needles it may be advisable to do so first as they will be quite wheel worn by now. cheers
Adrian
thanks for all the input. I have read about the unscrewing the nut to begin. In a TR4A book, and an SU Carburator manual I read two different numbers. One said to unscrew it two rotations (12 flats) and the other was two and half flats (15 flats). I have not tried the 9 flats, but probably got close. I will try again this weekend with the 9 flats.
That colourtune setup looks like it could assist in fine tuning.
Best regards
I used colourtune on my 68 Midget
2025 MG ZS EV aka Trigger
Didn't he object??? grin2
Seriously though, a useful bit of kit, mine seemed to vanish during the last house move frown
'09 Gen2 MINI Cooper ragtop
Still got mine but the cars I own are all injected now.
Vitruvius (good book on civils by the way) I have the British Leyland w/shop manual from my Midget using HS2 SUs, happy to send you a pdf if you pm me your e mail address
The tuning algorithm above is correct but is predicated on the carbs being in good condition with no leaks around the throttle shafts or excessive wear on the main needle or jet. If the SU's are worn you wont be able to clock them in no matter what.
'65 +4 four seater
Ha ha Graham. A colortune on a midget?
I did find a very nicely concise description of tuning on a midget website..(MG). http://www.mgcarclubdc.com/techtips/sucarbs.html
I'm still failing to get the acceleration up when I adjust the mixture. It runs well until 4500 rpm and it stutters... Perhaps a distributor overhaul and carb tune up is due this winter for the Dutchess.
