6 members (Sloany, Joe Speetjens, MATTMOG, John07, t50, John Winn), 280 guests, and 41 robots.
Adam12 69
+8Rich 68
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,389
Members9,215
Rbt Aero8, Salmon, stevends
Page 3 of 7 1 2 3 4 5 6 7
Originally Posted By 2013bluem3w
Is this the motor in the M3W (Retail $9,733.99)?
http://www.jpcycles.com/product/423-935?...CFWho7AodyhgA1g
Basically, with some mods to MMC specs ...
2013 M3W # 793
'Mosquito'
Originally Posted By planenut
I would go along with Easter on this, it is not in a "wet" area, it was running OK when the damage was noticed so the cam belt was still in place with no valve or drive train damage. It looks like the nut has undone and damaged the case. Torque it up and lock it, check the drive belt condition, temp repair the cover and use it until the replacement cover arrives. Fairly certain it's not as bad as it looks, not an engine change but a competant S&S engineer will know. I assume a trained Morgan dealer will know for sure?
thumbs cheers
2013 M3W # 793
'Mosquito'
According to the ad from J P Cycles, the S&S motor has a 3year warranty. I'd go along with the new engine camp, surely S&S should have it back to determine what went wrong. Gerry.
Gerry
Very simple. Either a lock washer was left off in assembly or the nut was not torqued down.
Guzzi had a similar experience with the first few hundred Grisso 4 valve engines a few years back. Seems the wrong type of washer was fitted in production.
AQM Offline
Originally Posted By Crowbar
I'm not really familiar with Motorcycle engines, or the S&S in particular...but are they "interference" engines? i.e. when the timing belt fails do the valves and pistons collide in catastrophe?
No, the X-Wedges are not "interference" engines. Luckily!
Surely it is still under warranty and if you do not get a new engine, and therefore a speedier repair, you will never trust it again.
I wouldn't run it till fixed. The belt must surely be damaged or will be damaged if run by the small bits of metal, ditto the oil seals behind the toothed gears.
2025 MG ZS EV aka Trigger
Does the dealer have a demonstrator M3w? If so, they should lend it to you until fixed.
AQM Offline
How did you find that out ?
I read about it.
A little about it here:
http://www.motorcycle-usa.com/313/1462/Motorcycle-Article/S-S-Reveals-Innovative-X-Wedge-Engine.aspx
http://www.motorcycle-usa.com/353/Motorcycle-Photo-Gallery/S-S-X-Wedge-Engine.aspx (there are explanations to the photos)
And here (which is where I lifted the pictures off of earlier:
http://www.beastmotoren.nl/customframes/x-wedgespecial/fotosx-wedge.html
http://www.beastmotoren.nl/customframes/x-wedgespecial/x-wedgespecificaties.html
And I remember reading it in SS Cycle's literature some time ago. They have manuals on their site.
AQM Offline
Found it:
Quote:
All cams for S&S X-Wedge engines feature the S&S Easy Start automatic, mechanical
compression release. The ease of starting with the Easy Start cams, coupled with
the fact that compression ratio does not increase proportionally with displacement
in X-Wedge engines, allows cams to be used with a wide range of displacements.
Production cams for X-Wedge are designed to be “non-interference” cams. That
means that if the valve train were to stop for any reason, there is enough valve to
valve, and valve to piston clearance to avoid engine damage from valves contacting
each other, or the piston
From this pdf:
http://www.sscycle.com/uploads/catalog/53/6%20Xwedge_WEB.pdf
