11 members (Mr K, JohnHarris, Mats, Julian BB, Biggle, JMcL, Sir Percival, mph, Bitsobrits, John Winn, Burgundymog), 399 guests, and 33 robots.
+8Rich 81
Topics49,859
Posts837,504
Jonny72
Some taper bearing applications (differential pinion bearings, for example)use a collapsible or crushable sleeve between the bearing cones. These bearings are torqued up to a yield value that causes the sleeve to compress and pre-load the bearings. This set-up is used on power transfer applications, but not at all necessary on light duty applications like front wheels on a Mog.
'65 +4 four seater
Hi
Your car has had a replacement "later" stub axle fitted at some point
in circa 1991 the factory moved the hub out by 1/8"- on the early production of this modification they simply fitted a spacer to the early stub axles
with the later production they actually modified the forging/machining detail
Simon
Mulberry Fabrications
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
