7 members (Gonze, t50, linklaw, RichardV6, Image, Paul F, Malcolm T), 386 guests, and 22 robots.
John V6 69
DaveW 67
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,022
RedThree
Some taper bearing applications (differential pinion bearings, for example)use a collapsible or crushable sleeve between the bearing cones. These bearings are torqued up to a yield value that causes the sleeve to compress and pre-load the bearings. This set-up is used on power transfer applications, but not at all necessary on light duty applications like front wheels on a Mog.
'65 +4 four seater
Hi
Your car has had a replacement "later" stub axle fitted at some point
in circa 1991 the factory moved the hub out by 1/8"- on the early production of this modification they simply fitted a spacer to the early stub axles
with the later production they actually modified the forging/machining detail
Simon
Mulberry Fabrications
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
