13 members (DCH, Graham, G4FUJ, MartO, Joske Vermeule, JamesS, TeddyAds, sewin, cerealsurfer, High Hamster, BLUE+4, Alistair, BobtheTrain, Image), 298 guests, and 64 robots.
+8Rich 76
Topics49,860
Posts837,520
Jonny72
Some taper bearing applications (differential pinion bearings, for example)use a collapsible or crushable sleeve between the bearing cones. These bearings are torqued up to a yield value that causes the sleeve to compress and pre-load the bearings. This set-up is used on power transfer applications, but not at all necessary on light duty applications like front wheels on a Mog.
'65 +4 four seater
Hi
Your car has had a replacement "later" stub axle fitted at some point
in circa 1991 the factory moved the hub out by 1/8"- on the early production of this modification they simply fitted a spacer to the early stub axles
with the later production they actually modified the forging/machining detail
Simon
Mulberry Fabrications
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
