1 members (JohnHarris), 323 guests, and 44 robots.
+8Rich 89
Topics49,841
Posts837,324
Christoph
HJP #155637 15/09/13 09:28 PM
Hi Matty - I had an exhaust shear at about 2500 miles. Same fault but on passenger side. Ledgerwood Morgan kindly sorted it out as a warranty claim - both exhausts were replaced in order to have a matching pair. The newer versions are a heavier gauge material, more suited to the job. Apparently a common fault.
JP
5 Guzzi's & A Mog
HJP #155638 15/09/13 09:57 PM
www.mcmastercarr.com has all sorts of vibration mounts including high temp silicone rubber. You can order on line wait a credit card.
Easily the best source for hardware. Top quality
HJP #155821 16/09/13 05:58 PM
Matty Offline OP
Maybe
I think I now know why the pipe is under stress.
The cylinder on the drivers side sits closer to the driver by perhaps an inch or so.
the down pipe should of course be shortened by the same amount. However when rebuilding the system today I noted that; even with the silencer slipped over the the down pipe as far as possible; the whole silencer and down pipe assembly had to be compressed horizontally with some force to enable the silencer mounts to match up with the support brackets on the body. Flex in the braided section is now extremely limited; defeating the whole purpose of this section.
inspection of the near side indicates that the silencer here does not need to be butted up to the limit in order to fit.
The drivers side assembly is always stressed to some degree even at rest.
it would be interesting to note if silencer failures generally occur on the drivers side on UK models
Matty Offline OP
Bang goes my theory. Thanks for that info. ii will push for two pipes
Rufus3 #155824 16/09/13 06:00 PM
Matty Offline OP
Refused to ship to UK last week
Rufus3 #155866 17/09/13 12:31 AM
Rufus - I can't find the actual link for the silicone vibration mounts on the McMaster Carr website...what section are they listed under?
1965 Plus 4
2008 997 Turbo Cab
1981 Alfa Spider
1954 Austin Healey 100 (SOLD)
2013 M3W (SOLD)
Look up " extreme temperature vibrations dampening sandwich mounts " or part # 4403k84
It's metric thread, don't know if its the correct thread, but numerous sizes are listed.
And yes they will ship worldwide, and friends in Europe and Tanzania buy from them . They are very good on the phone finding parts and setting up accounts.
Good luck
Rufus3 #155875 17/09/13 03:43 AM
Not sure if this helps at all, but the thread on my replacement rubbers for the rectifier mount is M8. Barely, but it works.
Good luck!
M3W, now!!!
DocNik #155956 17/09/13 01:37 PM
Originally Posted By Mi3Wheeler
I have ordered three of part number 4403K422 (Extreme-temp Vibration-damping Sandwich Mount Male/male, 5/16"-18 Thread, 50 Lb Compression Cap) from McMaster-Carr: www.mcmaster.com/?orderview=new#catalog/119/1376/=oerphs
These arrived and have been installed on my rectifier, total was $32 shipped to me, but they were not metric so I had to get 6 new nuts for another $12. They seem to be very similar to the stock mounts.
Charlie, Former Editor
Far from home this happened, I was touring in Ireland:
Complete shear of passenger side.
Luckily found someone at weekend to weld as a temporary solution.
