2 members (Ruut Bianchi, TBM), 94 guests, and 30 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,607
#155795 16/09/13 05:03 PM
Green & Grown Up
Green & Grown Up
Being like 'Skinner's Pidgeon' I keep doing that which I believe gets positive results. Therefore before washing the car I run 3 in 1 oil along both sides of all of the Beading Strips as recommended in my handbook. read
I have always believed that this process produces a moisture barrier to protect the Ash Frame, the worst spot being along the wings under the doors but I have no idea how deeply the oil can penetrate due to the tightness of the fixings?
Interestingly, during the visit to the factory last week I noticed that on current production, at any rate, the beading appears to be touching Aluminium on both sides of all of the joints where the Ash Frame runs for a depth of at least 12mm.
This is due to the amount of aluminium 'edge' that the guys hammer over the wood frame edges.
I have no idea how much 'edge' was used on our car and I will keep on using the oil pre wash, However, presumably the importance of protecting the frame should demand an 'oiling' before going out on a rainy trip? idea
Drive on the Wild Side
Some people are recommending using ACF50 and applying with a small syringe as it has very good anti-corrosion properties and repels water. So if you get any rubbing due to flexing between wings, body and beading exposing aluminium it may stop any corrosion developing. I have used ACF50 on a friends recommendation and others on TM. (By the way apparently WD40 absorbs water even though it initially repels it)
cheers
Adrian
I fully endorse Adrians comment on ACF 50. I think you will find that will also be endorsed by a number of TMers.
Neil
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
Yup! grin2
Yup! grin2
+1
Steve L.
1996 Plus 8
N22 MOG
I too am an ACF50 fan, it has kept my motorbikes in good nick over the years, as well as the metal on boats. I've done a bit of digging on its reaction with rubber and plastic. Apparently it is fine on rubber compounds, i.e. not pure rubber. As far as I know there is only one product that is made of pure rubber and I can't think of a reason why you should want to spray it with ACF50. However..........each to his own.
One thing I have always done during the layup period is to spray all hoses with silicone spray to keep them supple and Armorall on the tyre walls and plastics.
2015 Plus 4 (GDI) Sport Green
Just used ACF50 on the front suspension and wiring of my M3W - it looks amazing - better than factory fresh:)) plus the reassurance of knowing that this product will help protect against corrosion:)) it is expensive but I reckon that I used way less than 10% - so it will go a long way:)) unlike say a proprietary motor cycle spray the ACF does not evaporate - so the coating seems to staying put - recommended:)))))
Neil
Green & Grown Up
Green & Grown Up
Thanks for all of the positive responses and comments. cheers
I don't know of ACF 50 but will acquire some asap and get to work.
£14.48 inc. postage? I have just bought one
http://www.ebay.co.uk/itm/ACF-50-ANTI-CO...=item46107cffd4
Formerly known as Aldermog
In case you have many Morgans...
Bulk ACF 50
This is the UK importer's website: answers to all questions can be found:
ACF 50 Site
I use Duck Oil - - was recommended to me by a well known Morgan Repairer/Restorer. Never take wings or anything off so dont know how well its doing
Mike L
