1 members (Pittsartist),
150
Old Book
Topics49,940
Posts838,604
Posts: 3,727 |
Being like 'Skinner's Pidgeon' I keep doing that which I believe gets positive results. Therefore before washing the car I run 3 in 1 oil along both sides of all of the Beading Strips as recommended in my handbook. I have always believed that this process produces a moisture barrier to protect the Ash Frame, the worst spot being along the wings under the doors but I have no idea how deeply the oil can penetrate due to the tightness of the fixings? Interestingly, during the visit to the factory last week I noticed that on current production, at any rate, the beading appears to be touching Aluminium on both sides of all of the joints where the Ash Frame runs for a depth of at least 12mm. This is due to the amount of aluminium 'edge' that the guys hammer over the wood frame edges. I have no idea how much 'edge' was used on our car and I will keep on using the oil pre wash, However, presumably the importance of protecting the frame should demand an 'oiling' before going out on a rainy trip?
Posts: 4,896 |
Some people are recommending using ACF50 and applying with a small syringe as it has very good anti-corrosion properties and repels water. So if you get any rubbing due to flexing between wings, body and beading exposing aluminium it may stop any corrosion developing. I have used ACF50 on a friends recommendation and others on TM. (By the way apparently WD40 absorbs water even though it initially repels it)
Adrian
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
I fully endorse Adrians comment on ACF 50. I think you will find that will also be endorsed by a number of TMers.
Neil
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
Posts: 28,918 Likes: 354
Posts: 28,918 Likes: 354 |
Yup!
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
Yup! +1
Steve L.
1996 Plus 8 N22 MOG
Posts: 425 |
I too am an ACF50 fan, it has kept my motorbikes in good nick over the years, as well as the metal on boats. I've done a bit of digging on its reaction with rubber and plastic. Apparently it is fine on rubber compounds, i.e. not pure rubber. As far as I know there is only one product that is made of pure rubber and I can't think of a reason why you should want to spray it with ACF50. However..........each to his own. One thing I have always done during the layup period is to spray all hoses with silicone spray to keep them supple and Armorall on the tyre walls and plastics.
John 2015 Plus 4 (GDI) Sport Green
Posts: 6,538 |
Just used ACF50 on the front suspension and wiring of my M3W - it looks amazing - better than factory fresh:)) plus the reassurance of knowing that this product will help protect against corrosion:)) it is expensive but I reckon that I used way less than 10% - so it will go a long way:)) unlike say a proprietary motor cycle spray the ACF does not evaporate - so the coating seems to staying put - recommended:)))))
Neil
Posts: 3,727 |
Thanks for all of the positive responses and comments. I don't know of ACF 50 but will acquire some asap and get to work. £14.48 inc. postage? I have just bought one http://www.ebay.co.uk/itm/ACF-50-ANTI-CO...=item46107cffd4
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
In case you have many Morgans... Bulk ACF 50 This is the UK importer's website: answers to all questions can be found: ACF 50 Site
Posts: 5 |
I use Duck Oil - - was recommended to me by a well known Morgan Repairer/Restorer. Never take wings or anything off so dont know how well its doing Mike L
