6 members (How, JMcL, Hamwich, Ritchie B, Ruut Bianchi, nick w), 152 guests, and 22 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,610
Using ACF 50 on Bumble, but Tectyl 506 on the roadster.
I have just taken my front wing off as there was the first sign of corrosion creeping up from the beading under the door. (See Wing off in Classic Morgans) The problem with mine is the stainless steel wood screws that secure the stainless channel that hold the rear of the front wing. They are causing the alloy to corrode. The water tends to pool in this area and this is causing galvanic corrosion.
Oiling the beading has not helped as the oil has not reached the screws but the water obviously has.
I have bought some ACF 50 and will use this on reassembly.
I am however, insulating the stainless from the alloy using techniques learned from boats.
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
