4 members (DCH, MartinB60, cerealsurfer, RedThree), 375 guests, and 39 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,341
Christoph
Page 3 of 8 1 2 3 4 5 6 7 8
CMB Offline
I have asked SPAX to advise on that, I think that the current springs may end up being too long, due to the design of the adjustable damper. I think I will look into progressive springs, as I know that they can work very will, giving a good ride, but not too much body roll.
I do not know the poundage, I may get round to removing one and testing it if I have to, but SPAX should be able to provide this information.
I thought it would be intersting to re-visit these posts made in July by Gauis49 from SadFrancisco and Merlin the manufactuer of the Aero Cycle Car.
Gauis49 first:
So, I've done some more reading and I have a few considerations to post. The front geometry is bad for several reasons including:
1) The steering rack is too wide for the car, requiring short tie rods instead of longer ones. When the suspension goes up or down, the short length of the tie rod compared to the longer control arms causes the end of the tie rod to pull toward the chassis more quickly than the ends of the control arms. This in turn causes the steering arm on the upright to be pulled towards the chassis faster than the upright, which causes the upright to rotate about the kingpin axis. As this happens, the wheel's toe substantially changes.
The usual way to avoid this problem is to use tie rods that are about the same length as the control arms and to locate the steering rack so that the tie rod is parallel to a control arm.
2. The kingpin axis doesn't even come close to intersecting the tire contact patch. More precisely, the axis of the kingpin does not pass through the plane of the wheel at ground level. This means that there is essentially a lever arm giving the tire leverage over the steering. So when you hit a bump, the wheel is pushed backwards, this in turn creates torque around the kingpin which manifests in a sudden, violent jerk in the steering wheel. Basically the offset of the kingpin is dead wrong. This sort of error is quite literally a text book mistake,
"It is disastrous, as some of the pioneer designers discovered, simply to move the steering axis (the kingpin) smartly sideways [inwards]. That makes room for the hub and permits the swivels to be moved further apart, thus reducing the stresses on both. Sadly it also means that every road shock tries to twist the wheel about its steering axis - not exactly the kind of feel we were looking for. Far from each wheel being naturally self0centering, each will be trying to twist itself around its steering axis in a state of constant conflict with the other. Such permanent tensions are bad news in any kind of engineering, but especially in a system as safety-related as the steering."
-Car Suspension at Work: Theory & Practice of Steering, Handling, and Road Holding. Jeffery Daniels 1988. Page 77-78. ( http://www.amazon.com/Car-Suspension-Wor...pension+at+work )
I'll post more on this later. I've been very busy working 10-12 hour days at a new job, so my free time to post is sparse. I hope this helps explain whats going on with our beloved trikes. They are wonderfully fun, and I would enjoy mine even more if it didn't occasionally try to rip the wheel out of my hands and kill me when I hit bumps on the freeway (75mph+).
Good night everyone.
P.S. The exhaust heat shield mount tore out of the muffler last night, leading to quite a lot of noise and some improvisational welding. Enjoy -> http://www.youtube.com/watch?v=m5PbUq8lvww
And from Merlin, who make the Aero Cycle Car:
I have no bump steer on my Aero Cycle Cars either. The problem is that in essence Morgan have gone for a sliding pillar look with their upright. The camber is fixed, it cannot be adjusted, and it looks excessive, anyone know what it is, it looks in excess of 3 degrees, when 1-1.5 degrees is the norm.
next take a look at the wishbones, almost similar length, so arcs of travel are out. The precise location of the steering rack and angles in both planes of the track rod arms/ends is absolutely paramount, and is fundamentally wrong. They've used Mini/Metro ball joints top and bottom of the upright, however by using one at the top, there is no ability to adjust camber. Any vehicle built using Chapman/Lotus unequal length wishbones has used a top joint from a Ford Transit (drag link joint) either with a 20mm thread or an 18mm thread, thus allowing for adjustment....this is standard practice.
It is impossible to get exact "centre point steering"/"scrub radius"....ie extend the line down through both top and bottom ball joints on the upright to the ground alongside the tyre, then measure the lateral distance to the tyre wall. It can be achieved of course by the wheel having an offset, as of course modern cars always do now. If using motor cycle wheels (centre laced, or MWS MG TA outer laced wheels (as Morgan do) and these wheels are 2.5 inch rims shod with 19 x 4.00 tyres...and the wheels have no offset 9they clearly don't) then the extended king pin line will never intersect the centre of the tyre, but will come to within 25-30mm of the tyre's inner edge.
I've no idea why Morgan have exceeded even this...Triking and I manage within reason to get the closest, 25-30mm....we manage this by being tiny tiny one man band businesses, yet Morgan employ how many....over 180!?
My guess is having looked very closely at the suspension is that they've used or modified standard bolt on splined adaptors, rather than go to a specialist company called Orson Equipment to have had made combined splined hubs that could easily have achieved a far better centre point/scrub radius.
The wishbone length issue has not been thought out properly, they've tended to have gone for aesthetics rather than standard mechanical theory.
I drove their factory demonstrator around Blyton Park's track last October and found the front end extremely heavy. the overall experience was good on a track with no bumps of course. The following week the offside wheel came off this very car, as we know. Morgan have subsequently improved their wishbones apparently, but when both my fabricator and I looked closely at the top wishbones in particular, the welding looked rather lumpy and done rather cold, thus the "thick to thin" welds were incorrect.
There is room for a lot of improvement....so come on Morgan, do so!
I can't comment on the bevel box issue, but this is made by Quaife too, as well as the "cush drive" attachment between engine and gearbox.
So, to re-iterate, bump steer is primarily an issue of rack location and angles of the track rods and steering arms, and is so fundamental.
A very good book to read on front suspension is by Des Hamill, and has some easy to understand diagrams and text...it is a must.
I feel they both summerize the problem well, and it seems that if it is to be improved or fixed, more needs to be done than just raising the height of the steering rack tie rods with a spacer, or repositioning the steering arms on the uprights as the factory appear to be experimenting with.
The rack is too wide making the tie rods too short, additionally the king pin inclination is fundamentally wrong, giving kick back through excess leverage. Until these fundamental faults are rectified, I think that problems will not be solved, improved a little yes, but not solved.
It appears that MMC have more or less taken the design of the front uprights,wishbones, and steering arms direct from the Liberty Ace, with little in the way of modifications. The problem being, that they moved the steering rack behind the engine, and it had to be higher, therefore the tie rods had to droop, and the special Suplex shox were not available to hide the problem, and they did not have the time or inclination to redesign the front end geometry.
We will have to see where they are going with it, but until then, it is a matter of waiting patiently [or not].
CMB Offline
I agree with what you are saying in essence, but the way I see it is that the steering rack is too high in relation to the track rod end, this can be rectified with a spacer, or by lowering the ride height of the car until the track rod is level. This problem seems to be, at least in part, to the SPAX damper being longer than the SUPLEX unit which the front suspension was around.
Yes that is also part of the problem. The thought had occurred to me that an easy way of adjusting ride height could be made by a machine shop making the bottom spring platform adjustable, just by removing the platform and machining some grooves around its' base and using a circlip in it, then using a movable platform resting on the circlip. [I can't take credit for this idea BTW, it's been used on Caterham Sevens for years]. Of course, it would then be on the short side and could bottom out, but everything is a compromise, and this would be a relatively inexpensive way of lowering the ride height to experiment.
This still doesn't address the problems of the tie rods being a different length to the wishbones, so they pivot in a different arc, so causing the toe to change when the wishbones go up and down, or of the leverage caused by too much offset of the wheels.
CMB Offline
I am waiting for SAPX to get back to me regarding making a set of fully adjustable dampers. But I agree with you that this is only part of the problem.
MMC do not seem to be taking this problem to seriously, I have not been in direct contact with them, but I know Williams' (the dealer I use) initially said that MMC had told them that there was no problem with bump steer.
I do not feel that my car is dangerous to drive, or even that unpleasant, but I do feel that there is room for improvement.
Will MMC give us all their "fix it kit" I doubt it very much, unless it is deemed by someone to be dangerous and as a result they re-call all 3 wheelers, and I can not see that happening.
CMB Offline
I have received an interesting reply from SPAX:
"We are aware with the issues relating to bump steer on this car. Early cars had a longer rack the later cars had a shorter rack which has some effect. I have driven various cars and some are simply better than others. Having spoken to various people in the know which say the tracking makes a sizeable difference to how they behave regardless of rack etc. The first cars built had non European dampers supplied by suplex (spring manufacturer) and these had a spring on the outside as you'd expect and a spring inside of the damper.. Spring manufactures like this idea!. The idea was to limit vehicle lean using the internal spring in the damper to control the dampers extension. In practice it creates a step change in spring rate which can not be matched with step changes in damping rate. Good predictable handling always comes from smooth transitions of force/ geometry etc. Step changes in forces does not.
I have done more development on the 3 wheeler since the fixed rate dampers where designed, and we have developed a Morgan approved upgrade path. These are available from Aeroracing, I can't find them on there website which seams out of date, you may need to call them.
What we supply is a ride hight adjustable, damping rate adjustable kit for this car which makes a good difference to control wheel and body movement while retaining comfort. The spring rates are the same as we fit on the fixed rate dampers since these are in my view correct for the car. The rear springs are a shorter to keep the spring seats away from the belt. Naturally you can adjust the ride hight but be careful not to run out to suspension travel. With the adjustable dampers you can set the stiffness to where you feel is acceptable in the comfort/ performance compromise although the compromise was not significant. The damping characteristics are also different in the way they build force with shaft speed, we was able to give more low shaft speed control while keeping the high speed damping low enough to retain comfort. One of the development cars was a car local to Spax Hq, the owner was very pleased and even his co-driver (wife) noticed the improved stability and improved ride comfort which was very pleasing.
The front dampers on this car have to be quite special and we build them with a unique valving since the car is fairly unique and the motion ratio is such that the damper only moves 0.4" for 1 inch of wheel movement."
Gone to Porsche
Gone to Porsche
Although I do not own or intend to own a 3W I thought this maybe of some use to those looking in on the subject of Bump Steer , we used to experience a lot of this (Bump steer) when racing the Quads, we were not aware it was a defect called Bump Steer, we just thought it was 'us' crazy enough to ride the things over Sand Dunes etc at very high speeds and nearly lose control ooo
http://www.youtube.com/watch?v=17q0KMwT5Ls
http://www.youtube.com/watch?v=GFi9E5KmCAI
Don't call us....we will call you smile
Whilst down at the factory last week I was talking to one of the service guys and up until recently cars coming off the production line were set up with 2mm of toe out. My car was set up like this when I got it. It handled like a wild dog and would bite at every opportunity.
I then re-set this to zero toe, it transformed the steering, not perfect but much more predictable.
The service dept. now recommend 2mm of toe in, static and unladen.
When I get my car back I'll let you know how it steers.
This may take some time as it requires a new compensator and a few other bits.
I have M3W withdrawal symptoms!!!
CMB Offline
Today I made a quick trip to the factory, and purchased the suspension upgrade. by the time I got home and fitted it there was only time for a short test run, but the results are excellent. While there is still positive feedback through the wheel, the result of hitting a divot in the road at speed it far less than before. I have set the ride height so that the lower wishbone is parallel with the track rod (see photograph), admittedly lowering the car has caused a discrepancy in the tracking which I will attend to over the weekend, and as yet I have not adjusted the damping at all from the factory settings.
HJP Offline
Interesting , I didn't realise the upgrade kit was available yet , what does it consist of ?
Do you know if it's being fitted to new cars ? I was wondering if that's why there don't seem to be any pictures of the Brooklands 3 wheeler.
Hugh
