0 members (),
300
Topics49,897
Posts838,017
Posts: 47 |
The rear leaf spring on the drivers side has lost its boing! now the car is 2" lower on that side. It was a 5 leaf installed about 4 years ago in my 2004 plus 4. I will refit a 5 leaf spring, but my question is - Do I need to take the seats out to access the front spring hanger? and is it right the front shackle must be undone first? Thanks
Perilouspierre
Posts: 1,947 |
Can't help with the answers to your question as the only time I fitted new springs, I did it to a nude chassis so relatively easy.
But, you may need to fit a pair of springs as if the rates/stiffness's are different it could be horrid. Although the springs may be notionally the same, one is new and one is old.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
You might be able to squeeze the spring out with the seat in place but it's so easy to get the seat out that I wouldn't struggle with it in. The front mounting cover is held by self tappers into the wood, and the seat belt mounting. I can't comment on the order in which you do this job on Morgans, but access to the U bolts is almost impossible unless you block the spring in a compressed state, and then it becomes dangerous to un-compress. So that may be correct. What does Go-Mog say, because it's a fundamental of Morgan DIY jobs so I imagine there are some instructions on there.
Posts: 1,502 |
Posts: 519 |
The rear leaf spring on the drivers side has lost its boing! now the car is 2" lower on that side. It was a 5 leaf installed about 4 years ago in my 2004 plus 4. I will refit a 5 leaf spring, but my question is - Do I need to take the seats out to access the front spring hanger? and is it right the front shackle must be undone first? Thanks See: http://www.talkmorgan.com/ubbthreads.php/topics/138922/Project_4_4_4_seater_suspensio#Post138922for some pics and a few tips.  Neil.
1975 4/4 4 seater, cream over blue; Q3 Quattro; Bicycle; Walking poles.
I don't remember reading that Neil, but a great guide.
Posts: 519 |
I don't remember reading that Neil, but a great guide. Thanks, Dave. I take that as a great compliment coming from the Master of the Mog!  Neil.
And one day I know I'll have to do the same! Plenty of skinned knuckles on MGB rear ends, but not so far with Morgan leaf springs. When I need to do the job I'll be following your guide!!
Posts: 519 |
And one day I know I'll have to do the same! Plenty of skinned knuckles on MGB rear ends, but not so far with Morgan leaf springs. When I need to do the job I'll be following your guide!!  Neil.
