2 members (Alan Patterson, Graham, G4FUJ), 295 guests, and 34 robots.
John V6 71
DaveW 67
+8Rich 65
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,981
RedThree
Page 6 of 8 1 2 3 4 5 6 7 8
Thanks CMB, I think I will eventually go the adjustable spring platform rout at the front and fit 30mm shorter springs at the rear with the standard shocks.
If I or an independent garage change the front and rear suspension, no actual immediate plans but does anyone know if the warranty will be effected by this, obviously I know that the shocks etc that have been replaced wont be covered its just the items around these units, wiring etc?
Worst case you've changed the vehicle, warranty void scared
Trike Racing....
No but the "scary" factor is off the clock - protective clothing essential!!! ooo
Neil
PeterG - I would guess that if this an approved MMC provided aftermarket part/s then u would be covered - given that fitting etc is correct! read
Neil
No they wouldn't be the Aero MMC ones.
Q
Q
Where can i see the kit?on which web site?can the factory install it before i take delivery?its like 1 of the options
Q
Q
Aero-racing have gaz shocks and ear knock off only for the m3w
CMB Offline
Unfortunately you can not see the kit anywhere at the moment as it is not on the Aero Racing website, however If you call them they are very helpful.
CMB Offline
Peter, I would be careful fitting something that is different to what Morgan, of more importantly SPAX recommended.
SPAX said
"The front dampers on this car have to be quite special and we build them with a unique valving since the car is fairly unique and the motion ratio is such that the damper only moves 0.4" for 1 inch of wheel movement."
I am happy to admit this does sound a little strange, but you have no idea what you will do to the handling.
Suplex version at work
