7 members (jbk, rossocorsa, MartinB60, Clipper, Luddite, DazMog, High Hamster),
387
100
Topics49,868
Posts837,640
Posts: 152 |
Just a quick query,my dashboard light in my 2011 4/4 that tells me the heater fan is on has just stopped working,heater and fan are fine.
I assume then its not a fuse but the bulb which means pulling off the under dash panel to Replace it??
Any thoughts please
Jeff
Posts: 1,705 Likes: 35
Posts: 1,705 Likes: 35 |
Hi Jeff A thought... I’m not familiar with the 2011 dash but if Morgan were still using the round push button “EAO” 71 series switches assemblies, then the good news is the bulb (or led) can probably be removed from the front. The bad news is you need a special tool to remove the switch lens. However it is inexpensive and quite easy to get hold of at least in the UK. Manufactures data: http://www.eao.com/global/en/Catalogues/...1-Full-Data.pdfAlso picture of the removal tool here http://www.talkmorgan.com/ubbthreads.php/topics/141346/1
Roger 2011 Plus 4
Posts: 1,245 Likes: 30
Posts: 1,245 Likes: 30 |
Funny my 2011 4/4 has not got a light in the fan rotary switch nor the rotary heat selector. But hAs a light in the on/off windscreen heater. So should their be a light in the rotary switches ? It would be useful as can't see them in the dark thAt we'll Bob.)
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
I discovered today that my rotary heater fan switch has nine settings.......... Off Slow Fast Off Slow Fast Off Slow Fast.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Strictly come fanning? Nice to heat you to heat you nice.
Posts: 14,009 |
I'm not aware that there is a warning light for the heater fan...I assume you are talking about one of the lights in the bottom row of warning lights?
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 28,902 Likes: 352
Posts: 28,902 Likes: 352 |
Posts: 152 |
Sorry Jay Yes exactly, not a warning light just an on light I think Ill just have to pull off the panel immdeiately underneath and get to the bulb
Jeff
Posts: 295 Likes: 5
Posts: 295 Likes: 5 |
Jeff Sorry - only just seen your post. This confused me on my Roadster: it's not a "heater fan on light" ... it's an "air conditioning on light". In highly-sophisticated Morgan fashion, the spare push switch on the dash (used for aircon - where fitted) is linked into the fan switch - so that it lights up when the switch is pressed in and the fan is operating. I thought my "fan warning light" had stopped functioning too - but one quick press of that switch, and there it was again  My guess is that you have the same issue. So before you strip the dash - apply the number one digit to the snowflake
Nick Connaught Green Roadster S3 V6
