6 members (B3MOG, John07, John Winn, IcePack, +8Rich, Arwyn Williams), 280 guests, and 39 robots.
+8Rich 64
Adam12 62
John V6 57
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,319
Members9,215
I need a high level brake light to fit over my luggage on a two seat 4/4 and have seen the advert for the Simmonds kit. Does anyone have any experience of it? In particular I'm interested in how and where the socket is fitted and wether it's a hard task (as mechanically I'm a novice!) I have a 2013 4/4 with factory luggage rack and a MMC leather suitcase and 'H' straps.
Any advice will be gratefully received.
Andy
Laser red 4/4
Red Classic Mini Cooper Sport
Audi TT 2.0 TFSI Quatro
Do you have a spare wheel? Cars with spare wheel have a socket and a plug for the cobra with can be unplugged easily. The Simmonds set has different a cigar lighter plug and a cigar lighter socket according to their shop. So you would have to connect the cobra cable to the socket. If it is my car I would buy me the original plug from the cobra and solder it to the Simmonds light. At least your local Morgan dealer should have the plug.
BR
Christian
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
Drive on the Wild Side
At a show recently I saw a plus 8 with a high level warning light made from a classic stainless brake light mounted on a stainless tube above the the spare wheel. And fixed on a bracket in a similar way to the modern one. More aesthetically pleasing, I am going to look into this and will advise.
Adrian
Green & Grown Up
Green & Grown Up
Before Simmonds marketed their High Level Lamp I made my own
I got the Morgan's wiring harness maker (address below) to make me a 'Y' splitter so that I could just plug it into the line to the Cobra joint where there is a joint and leave it there permanently.
They made the one below for me and also supplied the extra socket for my Suitcase Brake Light cable. They told me it si important to get the brake lamp cables in the correct order re live and neutral to fit their splitter, which I did and it works perfectly.
If you source the sockets and are good a wiring you could make your own 'Y' piece
MES Ltd,
Unit A2, Harris Road,
Wedgnock Ind Est,
Warwick,
CV34 5JU
01926 499756
I would recommend to anyone else going this route to get the spare leg of the Y made much longer so that it may be lifted out of the spare wheel well when needed. This makes attaching the socket much easier. When its not being used this spare socket sits on the wooden cross member alongside the spare wheel attached to a strip of Velcro. I wrapped the other velcro around the cable.
The Socket types.
I hope that this helps.
Frank
Green & Grown Up
Green & Grown Up
If you fancy doing your own then One of the Connector Suppliers for the same Cobra line Connector used in the 2009 onward wirong harness is:-
http://www.polevolt.co.uk/acatalog/Econoseal_Connectors.html
Brum, Should you ever fit a roll bar, an led strip will add further to your safety.
I am adding a wind stop and will fit an LED onto it.
I am hoping with the hood up it will still be visible through the window
2025 MG ZS EV aka Trigger
My solution
http://www.talkmorgan.com/ubbthreads.php/ubb/showflat/Number/117220/
I do like the Y cable Frank 4x4 had made, and yes I agree one leg suold be long enough to clear the spare wheel.
Thanks everyone. Very much appreciated as ever.
Andy.
Laser red 4/4
