11 members (deano, MJF, +8Rich, RedThree, moggin, Image, BLUE+4, RichardV6, TBM, DaveW, linklaw), 241 guests, and 54 robots.
+8Rich 78
DaveW 51
Topics49,864
Posts837,573
#159760 11/10/13 03:40 PM
deano Online Happy OP
OP Online Happy
Whilst doing some routine maintenance on my plus, I was very surprised to see cheap and nasty exhaust clamps MMC have used. For £5.60 (retail and including postage) I have replaced them with a quality fitting. When removing the MMC clamps I was also surprised to find the threads stripped on both sides.
Martin (Deano)
Gone to Porsche
Gone to Porsche
Originally Posted By deano
Whilst doing some routine maintenance on my plus, I was very surprised to see cheap and nasty exhaust clamps MMC have used. For £5.60.
I disagree there Deano, the cheap clamp as you describe it has been used very successfully in the Exhaust fitting world for decades was easy to remove when you had to change a section of pipe. Your more expensive counterpart may prove more difficult to remove once it gets a bit rusty and cold welds itself to the pipe. surrender
OP Online Happy
Well after 3000 mainly dry miles, I can assure you the MMC version where not easy to get off. If the new ones do rust and prove difficult the undo, then you just cut the one bolt and replace it!
Martin (Deano)
Green & Grown Up
Green & Grown Up
The new one looks smart thumbs .
Is it Stainless Steel (or available in Stainless? ) shades
As you said the old clamps were difficult to remove I expect the threads stripped as you were 'unfreezing' them...
Finding a similar type clamp in stainless steel seems difficult (for a sensible price) in UK and some have imported them from across the pond.
OP Online Happy
Stainless steel, purchased on Ebay. I noticed Williams where fitting the same with their stainless systems. Also on the M3W from the factory.
Martin (Deano)
Librands supply similar clamps, they are s/s.
Drive on the Wild Side
After 2 years the Librands clamps on Rosie's exhaust undid easily, I was swapping her boxes to make her a bit quieter and more civilised for touring.
Adrian
A disadvantage of the "U"bolt style is that the loop(U) part can put a crease in the pipes (outer and inner) so that even when the clamp is removed you still cannot pull one section out of the other. This is because they have been over-tightened to compensate for a poor fit at the joint or just too much enthusiasm.
'65 +4 four seater
