8 members (Moggo, John V6, Hamwich, itsfrank666, LE52MOG, Grumpy2, GrandadC, Richardllll), 320 guests, and 40 robots.
Adam12 69
+8Rich 68
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,388
Members9,215
Rbt Aero8, Salmon, stevends
Page 1 of 5 1 2 3 4 5
#15545 21/03/08 04:04 PM
JohnS Offline OP
Just taken delivery of new V6 Roadster Very Pleased Overall
However when it rains I have a puddle of water to the right of the handbrake on the transmission tunnel
Anyone any ideas
kin Offline
Welcome John cheers
The only thing i could think of was that the rainwater get blown thro the heater vents confused2 just my 1/2cent.
Some of the night owl members here should be able to give you better advice later on tonight wink
Any pics of your Roadster?
kin #15550 21/03/08 05:56 PM
You take it out in the rain...?
rofl
Anyone any ideas
Have you checked the seal where the roof meets the top of the windscreen?
A question that may sound silly at first: when you close the roof, do you do it alone? I.E. pull it up, lock one side down and then run around and lock the other?
The reason for this question is sometimes you can 'seal' the roof on an angle (I used to have this issue with my Aero) and while it looks closed, the roof isn't aligned as well as it can be.
The way around this is to close the roof with a person on each side, or if doing it alone, make sure you apply pressure to the middle of the roof (from the outside) when closing it - and then jump inside the car and lock down the two clamps at once. This should give a much better seal.
Try this and see if it makes a difference.
If not, the hood may not be sitting true to the windscreen and therefore will need to go back to the dealer to be sorted.
smile
JohnS Offline OP
Thanks for the replies
The leak is not from the hood
It is from under the dash so looks like it comes from the scuttle
It also does not seam to leak when on the move only when parked
JohnS
I would suspect water coming down through the heater both my 4/4 used to & now my +4 does this when being washed.
You can buy a storm cover to cover & that worked when my pride & joy was parked outside due to furniture being in the garage whislt we extended our house.
2025 MG ZS EV aka Trigger
The old bulkhead joints used to leak as well but I thought the factory had fixed this one now. Try lying in the footwell with the bonnet open and a bright light shining down on the engine bay... see if you can see light anywhere.
There has been a demo photo posted recently of course innocent
http://www.talkmorgan.com/ubbthreads.php?ubb=showgallery&Number=15023
Phil Egginton
1979 4/4 4 seater
kin Offline
Hi John,
Have you sorted out your problem yet? If so, what was the cause?
kin #16193 12/04/08 11:11 AM
I have the same problem with our new Roadster, it leaks when stationary or on the move. It comes in from behind the dashboard somewhere and drips onto the leather next to the handbrake.
I'll try and get a better look at it soon, but any other ideas are very welcome.
Regards
Mark
Mark #16198 12/04/08 04:52 PM
JohnS Offline OP
Kin/Mark
Not sure but I put some vaselin around the screws which hold the bonnet hinges
Up to now have not had any water around the handbrake
Hope I have fixed it but not convinced
John G4TKO
