9 members (deano, Julian BB, Alan Patterson, Image, Roady, Clipper, RichardV6, Hamwich, Pittsartist), 279 guests, and 74 robots.
+8Rich 80
Topics49,859
Posts837,511
Jonny72
#162497 28/10/13 05:23 PM
Nigelp Offline OP
Hi folks
The heat shield on the upper catalytic converter (single exhaust system) on my 1993 Plus 8 has disintegrated. Apparently these are no longer available (unless anyone knows different).
From what remains it appears to have been made of some sort of fibre material. I am faced with trying to make something up myself to fit on the bracket, or coming up with another solution. I'd be really interested to hear if anyone else has any experience to share on this...
Many thanks
Nigel
(long time lurker - first time poster!).
You can still get reflective coated asbestos(?) heat shield. Try Demon Tweeks for starters (then look around for a cheaper source!).
Green & Grown Up
Green & Grown Up
Agriemach is my supplier of choice - no connection.
Drive on the Wild Side
I would suggest making up a stainless steel plate shaped to a curved shield and bolted to a bracket so it is position 1/2" or so from the CAT, I think there is enough room. Before final fit fix the reflective heat shielding to it from one of those already mentioned. cheers
Adrian
I have used thermal barriers from Zircotec in the past. Very effective and a nice company to deal with.
Jays #162663 29/10/13 07:24 PM
Nigelp Offline OP
Thanks to all for your help with this.
Best wishes
Nigel
Nigel
'75 +8
