1 members (Bishmog), 310 guests, and 41 robots.
John V6 70
DaveW 67
+8Rich 65
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,980
PPP356
Page 5 of 7 1 2 3 4 5 6 7
+1
2025 MG ZS EV aka Trigger
Very smart. Your clock is a good filling for that space.
Ian
Well, that machine turned centre panel looks lovely John, great contrast with the gloss black dashboard, really lifts the interior. Worth all the (your!) effort... IMHO thumbs
Re the wing top lights, funnily enough I had a problem with one of mine recently (on the near side). I assumed it was a failed bulb, but no. It turned out to be a connection pulled out under the wing. There are a pair of bullet connectors (+ve & -ve) near the wing stay bar, and the +ve wire had pulled out of the bullet, so it was a simple re-crimp for the repair. May be that your lights are just not connected there... hopefully smile
Philip.
Jays Offline OP
Thanks for the tip Phillip...I'll have a good look tomorrow.
Definitely Old School
Hello Jay---Do you remember our pub lunch during a MMC factory visit a couple of years back----I also bought a Mig clock off Ebay with a black face, which before I fit (or have fitted because unlike you I lack the courage and know how) I will need to repaint ivory to match my Roadsters ivory retro instruments.It will be enough of a challenge to paint the digits, but I am game for that part at least.
Really impressed how you have made yourself an original one-off dash---really fantastic---and a real improvement to boot!!
All the best!
David of SW19
Jays Offline OP
Hi David! Yes I remember our pleasant lunch quite clearly......and recall you clambering into the Plus8! Good luck with painting the clock face...a steady hand! You do have some skills I recall. At least the clock comes apart easily...I took the front off to strip and polish the bezel.
Cutting the hole isn't too bad but because of its shape there is no room for error..you can't straighten up the clock by turning unlike the usual dash clock!
I look forward to some photos in due course!
All the best.
Looks great Jays
Drive on the Wild Side
Originally Posted By Jays
What a struggle getting the dash back in! When I bought the car the dash was very slightly loose...the reason turned out to be the top mounting screw had missed the ash frame under the cowl! Must be down to being hand built.....I thought that the dashes and frames were jig made to a pattern. I managed to mount the dash slightly higher but then that meant trimming the plastic under tray. Backbreaking work in a cramped garage! Still...it's all in, looking good and the glove compartment looks a lot better for the mesh.
The next job Phillip? I want to get the wing top sidelights working......the wiring seems to go off somewhere under the wings so a bit of grovelling tomorrow.
Really lovely job. Once you've got the wing lights working, you might want to think about fitting Led's, I have fitted 14 LED ones, nice and bright in the daylight. cheers
Adrian
Jays Offline OP
Thanks Adrian. I picked up a set of led bulbs a while ago meaning to put them on the 4/4.
Retired, not expired
Looking the business ........ very smart
