0 members (),
141
41
Old Book
Topics49,940
Posts838,603
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
 do you know what is it this hole ?
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
It's the hole that gets drilled in the underside of the compensator bell housing to allow access to the grease nipple that is fitted to the current version of the compensator.
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
It's where a three legged mouse lives...which isn't quite the technical explanation of Calums!
Posts: 1,959 Likes: 15
Posts: 1,959 Likes: 15 |
Posts: 979 |
It's the hole that gets drilled in the underside of the compensator bell housing to allow access to the grease nipple that is fitted to the current version of the compensator. Looks as if it should definitely have a rubber (or neoprene) plug in it though!
Possibly...but there is an enormous hole in the top of the housing where the steering rack sits so having a hole in the underside might make for a good drain.
Posts: 3,568 Likes: 14
Posts: 3,568 Likes: 14 |
And there I was, worried about water getting into the steering rack through the tiny little hole in it!
Posts: 1,653 |
Water Paul, be afraid, be very afraid!
Posts: 1,213 |
Aaagh ! I'm pretty sure my compensator hasn't got that hole , does that mean it's full of water ?! maybe that's why its quiet at the moment ....
Hugh
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
The factory service dept. told me they drill a hole in the bell housing and then drill and tap the compensator to fit a grease nipple to it so at service time it could be pumped full of grease to keep it quiet. Rather like grease nipples on prop shaft uj's.
