4 members (MJF, Nickplus4, DaveW, deano), 93 guests, and 43 robots.
John V6 63
Luddite 54
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,606
pantsdown
do you know what is it this hole ?
It's the hole that gets drilled in the underside of the compensator bell housing to allow access to the grease nipple that is fitted to the current version of the compensator.
SBM Offline
It's where a three legged mouse lives...which isn't quite the technical explanation of Calums!
grin2
Looks as if it should definitely have a rubber (or neoprene) plug in it though!
Possibly...but there is an enormous hole in the top of the housing where the steering rack sits so having a hole in the underside might make for a good drain. laugh
And there I was, worried about water getting into the steering rack through the tiny little hole in it!
Water Paul, be afraid, be very afraid!
HJP Offline
Aaagh ! I'm pretty sure my compensator hasn't got that hole , does that mean it's full of water ?! maybe that's why its quiet at the moment ....
Hugh
The factory service dept. told me they drill a hole in the bell housing and then drill and tap the compensator to fit a grease nipple to it so at service time it could be pumped full of grease to keep it quiet. Rather like grease nipples on prop shaft uj's.
