9 members (GrumpyPa, LeeM, meabh, Mog on Island, xc68anc, Lordofthewings, Image, Graham, G4FUJ, RedThree), 295 guests, and 33 robots.
John V6 65
DaveW 63
+8Rich 62
Dufty, Anted4, 4199, GOFFO1965, Joske Vermeule
9,212 Registered Users
First Morgan
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Topics48,349
Posts813,103
Members9,212
aeroed, DJC, James Mc, JimWhin
Read T Offline OP
I'm trying to remove the brake drums from the rear of my 1960, I've removed the 4 hex bolts, I shouldn't have to remove the adjusting round headed slotted screws, but that dang thing won't budge. I've been smacking it with a hammer and am about to get out a torch but didn't know if anyone has a suggestion on how to get it off.
Probably hasn't been off the car since 1959.
Looks like this for reference:
1960 Morgan +4 4 seater
1997 Nissan 240sx S14
2011 Nissan 370Z
2009 Triumph Street Triple
Make sure that the handbrake has totally released, and if you have manual adjusters on the back, slacken them right off.
If you take out the slot heads, you might stand a better chance of rotating the drum - try a socket on the centre nut to hold the hub still.
Good luck!
Read T Offline OP
Thanks Dave!
2011 Nissan 370Z
Read T Offline OP
I've also contemplated drilling a hole into the drum over the hub and tapping it, then screwing a bolt through to press the drum off
2011 Nissan 370Z
It will be a challenge tapping that hole!
Once you've broken the rusty seal try rocking side to side, or hammer side to side........
Drive on the Wild Side
Might need a puller or a bit of heat, recommend you use a hard rubber mallet if hitting it.
Adrian
Read T Offline OP
Pryed on it with a huge screwdriver.
This is after cleaining it for a while with brake cleaner
2011 Nissan 370Z
Well done! thumbs
Read T Offline OP
I'm more proud of these beauties myself. Buddy of mine works for a brake company that supplies to ALMS / NASCAR etc and helped clean them up.
2011 Nissan 370Z
Read T Offline OP
And my newly powdercoated Daytons
2011 Nissan 370Z
