Topics49,859
Posts837,472
Posts: 49 |
i have an oil pump leak due to a failed seal on my 1.6 cvh 4/4. i've studied it for a while and access looks a bit tricky without a lift to get access underneath the car. i'm weighing up whether to bite the bullet and pay for it to be done in the garage.
but before i throw in the towel as i would much rather have the satisfaction of working on it myself can anyone give me any advice how i might go about it, do i need to remove the radiator for example?
many thanks
1995 Plus 8 1984 4/4 4 Seater (prev)
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
If the seal is your sump gasket then the engine will have to be removed . The sump can not be removed by just those bolts that hold it onto the block . You will need the rad out and their is an engine eye at the rear just above the heater pipes ( could have your leads in it ) . MAY ? be another just above the inlet exhaust at the very front . If not you can buy one on the net or go to a scrap yard . Have a look at some photos first and ask others . Good luck . i have an oil pump leak due to a failed seal on my 1.6 cvh 4/4. i've studied it for a while and access looks a bit tricky without a lift to get access underneath the car. i'm weighing up whether to bite the bullet and pay for it to be done in the garage.
many thanks
Posts: 49 |
thanks for the reply. the leak is from the oil pump that bolts onto the front of the engine and a failed seal on that, i'm pretty sure its not the sump. certainly when i've had the engine running the oil is coming from that pump.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Should be doable at home and I doubt it's linked to the sump.
Richard 1976 4/4 4 Seater
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
1972 4/4 2 Seater
Just going off what was done to mine in the mid 90s the oil pressure dropped to very low ( unable to remember what ) part of the pump had broken ( looked from memory like a sprocket with broken teeth ) . May be why the engine and sump came out . thanks for the reply. the leak is from the oil pump that bolts onto the front of the engine and a failed seal on that, i'm pretty sure its not the sump. certainly when i've had the engine running the oil is coming from that pump.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
I have the Haynes manual that covers CVH engines - bought when I had a 92. 4/4. It details how to change/dismantle a d rebuild oil pump. Haynes show it done with engine out so I don't know how easy it is in a Morgan withe the engine in situ. A couple of points include........ Remove timing belt/ sprockets/sump. If just replacing the gasket then refurb of pump itself may not be needed but a new oil seal for the pump housing is recommended. Pump should be primed before refit. Refitting the sump involves using sealing compound at both ends - pump end and rear. The procedure is obviously for the Escort/Orion's the engine was mainly used in so an in-line set up may lead to differences in access etc for a Morgan. I can't remember enough about it as I didn't need to do any such work. Vaguely, it is possible it will be straight forward with a car high up enough off ground for access, BUT.... Morgans have in line gearbox (Ford type 9 usually) so there MAY be bell housing set up differences to deal with. Best bet is to see if someone here has replaced a sump on a CVH to see if any complications were found. At face value it should be do-able at home with good axle stands though. If you want the Haynes manual then PM me. You have first refusal if anyone else wants it. sospan
Posts: 49 |
thanks for the comments. i'm pretty sure its not the sump but the seal in the oil pump or if there is a gasket on the pump onto the engine.
just a shame i cant get the car up on a lift and have a look at doing the job properly.
sospan thanks for the offer, i have sent you a pm.
