New
Topics48,365
Posts813,378
Members9,215
Posts: 410 Likes: 5
Posts: 410 Likes: 5 |
So I've gotten my permanent license plates and I'm wondering how most of you are affixing the plate to the car? are you drilling holes in the mounting plate? I'm thinking that using automotive grade double sided foam tape is the way to go...
Input appreciated.
1965 Plus 4 2008 997 Turbo Cab 1981 Alfa Spider 1954 Austin Healey 100 (SOLD) 2013 M3W (SOLD)
Posts: 14,723 Likes: 149
Posts: 14,723 Likes: 149 |
I tried that but found that when it got hot the plates started to lift off. Stainless screws, washers on the back, and nylocks are much better.
Posts: 1,338 |
Try 3m double face tape..tried it on many things plus cars..does the job
Posts: 1,642 |
The front plate of a Plus 4 (suppose all trads) is to be placed on a curved surface, so either the plates themselves are shaped to fit that surface (if they're made of metal it'll be easy) or the tape will probably not do the job for a long period of time. As for the M3W, I don't think the front plate is needed in Portugal (not sure about other countries but won't derail another thread by asking  ). The small rear plate will probably do with anything, from tape to stainless screws. I think (but not sure), tape is not exactly "legal" in Portugal, but I never saw traffic police here looking at it or causing anyone trouble because of it.
Posts: 15,794 Likes: 14
Posts: 15,794 Likes: 14 |
As Mario said, tape and heat mean tht tape won't hold the plastic UK front plate, so two screws needed. But at the back tape seems fine.
The UK has no rules about fixing plates, other than they must be "secure".
Posts: 1,562 |
The deal fixed mine - seems to be some sort of glue !
Posts: 410 Likes: 5
I bought a metal black and chrome "novelty" plate for the front...no holes drilled...
Going to try the 3M automotive trim tape and see if it holds.
Posts: 797 |
The backing plate will vibrate lose at some point, so: Remove backing Plate Temporarily fit number plate with Masking tape Mark pilot holes on back of number plate using backing plate fixing holes as a guide Drill out these holes to slightly larger than supplied fixing machine screws Choose a couple of good spots on the number plate and drill two M6 clearance holes through number and backing. Countersink these holes using countersink tool or the biggest drill in your toolkit Fix number plate to backing plate using M6 c/s socket headed machine screws and nylock nuts. You can now fix and remove the backing and number plate without having to prise off the double sided nastiness.
Don't forget to thread lock the backing plate screws
Posts: 3,827 Likes: 4
le Asbo du Bling Talk Morgan Addict
Posts: 3,827 Likes: 4 |
Take it off and put in the trash box. I've taken mine off and not had any issues from  yet.
Slowly going green
Posts: 797 |
Do we not need one by law?
