1 members (davewhite), 277 guests, and 67 robots.
+8Rich 75
Topics49,861
Posts837,540
Jonny72
Page 1 of 4 1 2 3 4
#168331 30/11/13 05:06 PM
Hi,
I have a problem with on my 1800 Zetec 4/4 (2001). When I accelerate the revs stay up momentarily. This happens when hot and when cold. Is there a setting I can change to stop this.
Also, do any of the dealers run service training sessions. I'm sure I've seen adverts somewhere but I'm unable to find anything on the internet.
Thanks
Phil
Regards
Phil
2001 4/4 Red
Just in case Minikeefy doesn't sport this, here's his response to someone who asked about this before:
Have a look at my website for the LeMans62 Register I have posted relevant information on this problem that should help (under Rev Hanging)
Basically you should start with resetting the ECU as described in the documents and if the garage is used to Fords this should be easy. It is not the same ECU as Ford but a specialised Morgan version (need I say more!)
I now reset it at the annual service and has seemed to have solved the annoying problem.
Good luck.
Here's the link...http://www.lemans62.org.uk/Tips.html
Thanks for that, I've downloaded the info and will ask for the ECU to reset.
Thanks again
Regards
Phil
2001 4/4 Red
Hi Phil, Brands Hatch Morgan do maintenance training courses, which have had good reviews on this forum. Drop them an email to find out when the next one is. Gerry.
http://www.morgan-cars.com/2013/08/an-example-event/
Thanks Hamwich for pointing to my website.
I can still vouch for the fact that my car still 'behaves'. So seems to be an inexpensive solution to the problem.
Good luck. drive
Keith
Good luck.
I have the same 'problem' with my 4/4 -99 Zetec silver top engine. Is there a similar solution available for my ECU?
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Hi,
I had the same problem on my 2001 4/4 black top zetec.
The only fix that worked for me was to install a restrictor plate behind the idle speed control valve.
The first I bought from an Austrian Morgan dealer. Now I\ve started to manufacture them myself from beer cans.
In the end I chiseled out the internals of the idle speed control valve, before installing a new beer can restrictor plate.
I made the holes small enough to achieve an idle of 900.
When the engine is cold in cold weather it runs rough, but when warm, very nice idle.
Now I can engine brake downhill, and accelerate as hard as I like without any hanging rev.
4/4 2 seater 2001 model
Thanks for info and picture Geir smile
Does it matter which way the plate goes? - the holes are of different sizes... and, what sizes did you end up with?
Just a thought thinking : it 'feels' like the cause of the trouble is that the mixture is too lean - too much air. Could raising the fuel pressure help perhaps...
It doesn't matter where the holes go.
I think I now run with two 6mm holes.
On my car it is a software problem. The software which manages the engine is very bad.
It opens the valve letting more air into the engine, then adds fuel increasing the revs.
If you have a problem but run a silvertop engine I would start by examing the valve. Because I think your software is different, and even better.
My valve sucks non filtered air from outside the air filter. So after a while it gets stuck or moves very slowly, staying open longer than it should.
The valve is operated by an electric magneto(solenoid)which opens or closes a plastic piston kept in place with a spring.
Remove the valve and push the piston open. If the spring don't push it back, the valve is dirty or worn out.
You can clean the valve using electric cleaner. In my case the lubrication made it function better for a while, then it got stuck again.
I also put current on mine to check if the electric magneto could move it.
Page 1 of 4 1 2 3 4
