3 members (Strathaven, Pundit, B3MOG), 208 guests, and 86 robots.
+8Rich 79
DaveW 50
Topics49,866
Posts837,588
Page 20 of 94 1 2 18 19 20 21 22 93 94
Q8morgan #168694 02/12/13 09:50 AM
Looks very smart.
Q8morgan #168715 02/12/13 03:24 PM
thumbs cheers
2013 M3W # 793
'Mosquito'
The Seeker #168716 02/12/13 03:27 PM
Looks superb.
It may have been asked before - but where did you get your steering wheel from?
Red Leader drive
Chris99 #168730 02/12/13 05:25 PM
Q
Q
-superspoke 13.5 with thumb spats
-top plate & nut
-quick release boss
-gear knob
Simmonds of malvern
Q8morgan #168842 03/12/13 11:31 AM
-top plate & nut
-quick release boss
-gear knob
Simmonds of malvern
Thanks - I'll give them a call.
Red Leader drive
Q8morgan #168981 04/12/13 03:01 AM
Did you get your tracking sorted Q8?
If you've tried all the normal stuff, you might look at the rear wheel, I don't know for sure what would happen if it was slightly out of alignment, but that might affect the tracking to left or the right.
Just a thought.
Q8morgan #169047 04/12/13 12:31 PM
Q
Q
Im going to have to do it because its really bothering me,the wheel is not centered as well
Q8morgan #169280 05/12/13 10:39 AM
For some reason (possibly to allow us to see the instruments a bit better) the wheel on almost all M3Ws is not aligned straight from the factory.
Harder to fix than you might think, I believe - requires pulling back the whole steering column and re-siting on the steering box.
Might be wrong on this one!!
Q8morgan #169452 05/12/13 10:14 PM
Having the steering wheel, even slightly, out of alignment when straight ahead is so annoying, I can't stand it.
The best way I've found of straightening the wheel, is to change the tracking of each front wheel by screwing the tie rods in or out, exactly the same on each front wheel. It is a bit of trial and error, but does work. A word of warning though, just make sure that both wheels are moved in the same direction, it's really easy [for me at least] to move the wheels in opposite directions, and lose your toe measurement completely. I mark the track rod end with a small dab of white correcting fluid to indicate the amount of thread used.
Q8morgan #171333 17/12/13 11:17 AM
Q
Q
Thanks to Crowbar,do you approve of the installation?is the bracket at the same level as yours?now its on 3m,but im going to buy 3 screws
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zps4a89705d.jpg.html][/url]][/url] [url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zps0946afd3.jpg.html][/url]][/url]
