0 members (),
312
Posts837,998
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Its getting near Christmas so I went into Machine Mart to purchase a impact screw driver or a socket with a screw driver fitting just to get that bit of strength on it and a connection for my compressor . They did not have any . I must be catching something off shopping with my wife and daughter , So I purchased a Aluminium racing jack lifts 1.25 ton £107.98. I have had a 3 ton Webber for years but its just to high to slip under the chassis and the mog has to be driven onto a bit of wood . It has a part rubber filled end so as not to scratch , but still has a metal edge around the rubber . I going to make a jack pad but need a bit advice does anyone know of a mog owner thats makes things out of a rubber stuff for his mog .
Posts: 20 |
I bought an ice hockey puck on Ebay which is a perfect fit for my trolley jack and it's made of hard rubber.
Seems just the job.
Tim 2011 Roadster 3.0 V6 Sport Red
Its 10cm in diameter . Thanks for the tip I know what I will be doing on Sunday .
Posts: 2,583 |
You need a good thick piece of Neoprene!! Thought I`d get in before Dave W !!!
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
Hockey puck... Neat idea - I guess the price on eBay is about to go up!!!!
Posts: 3,643 |
I also use hockey pucks for jacking up. Those of you with Minis will recognise that they have hollow jacking points. I cut down a hockey puck to fit the hole much stronger than a small block of wood.
Posts: 986 |
Where do you place the trolley jack? Anyone got a picture?
Andy
Laser red 4/4 Red Classic Mini Cooper Sport Audi TT 2.0 TFSI Quatro
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Rear with jacking beam:  Front with jacking beam:
