1 members (ChrisConvertible), 206 guests, and 89 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 9 of 12 1 2 7 8 9 10 11 12
I just charge mine through the 12V supply in the cockpit. Saves fiddling with that daft cowl / bonnet that seems to take me about 15 minutes to get back on.
Can't forget it's plugged in either since it's right in front of my nose!
Originally Posted By Blake
-better build quality/qc. tolerances are still garbage. all my body panels rub against each other in places they shouldn't which have rubbed off bits of paint. my body has eaten through the rubber bits around the roll bars due to dermot alignment and created nasty sounds right behind your head.
-complete rerouting of the wiring harness. if you take a look at a good portion of the wiring it sits sandwiched between the frame and the engine which in lots of cases has caused shorts/damaged wiring because it gets crimped or severed over time
-rerouting of throttle cable (which some have already done in the aftermarket (i know melvyn has done it and i've had it done through a local guy)) to get rid of the unsightly cable sticking up form the engine
-fix the gaps under the dash flanking the bit of upholstered leather above the transmission tunnel. next time take a look and stick your hand in there, you can grab a handful of wiring. very unfinished looking
-rear mudguard/fender
-did i mention fit/finish QC?
-floor mats that don't move around, especially the one by the pedals on the driver's side
-reengineer the bit of framing that is at your heel by the pedals. makes for awkward positioning of your feet
-trim down the tranny tunnel. another mod that people have done independently (getting mine done this winter). there's another inch or so of width that can be reclaimed for your legs (waldemar had this done as well)
-glove box mod
-redo engine mounts. for those of us who have had to witness the engine being pulled (mine has been pulled twice and i've seen kevin's pulled 3 times) it's absurdly complicated to pull out and even worse to put back in. part of the problem is that when the car is assembled it's easy to put the engine in without the body on but once the car is fully assembled and body is on it's a mess to remove and put back. i've talked with a couple buddies who work on race cars and they've all had some great suggestions for redoing the part behind the numberplate which would allow you to pull the engine directly out
-all the rough topped hex bolts in the interior where the leather seat pads sit against which after the first month of ownership will end up cutting in to the leather and pretty much destroying your seat cushions. if you don't believe me pull your seat cushions up and look at them, they look like hell
-on a similar note to the seat cushions, work on the rough edge of the body where the top of the seat back is pinned underneath/behind, it also cuts in to your leather. was super disappointed when i pulled my interior apart to do my dynamatting which revealed what poor shape everything was in
-find a way to change the rear tire without having to spend a couple hours pulling everything apart. it's really really really complex to get the thing off and requires a proper lift. not something that could ever be done when dealing with a flat on a trip
-louder! i agree with peter. car needs more nuts to it. when i got to hear the ace cycle car i realized how gutless the morgan sounded. not looking for an obnoxious harley sound but just something with some more meat to it.
-fix the pinging sound at high rpm
-faster. would love to have the 4.6 sec car that was advertised to us. our cars are quick but not fast. while i realize that too much power would be lethal in these things i do feel like it's being substantially held back
bitches aside it's a blast to drive but in the spirit of constant improvement it's important to be fully open and honest about the cars shortcomings or areas that could be made better.
Blake - To help with the high RPM pinging try using good quality high octane fuel -AND- a high quality octane booster
Is your recommendation to use high octane fuel and a booster based on experience or just a suggestion emiguy? Just wondering as I get the high RPM pinging noise but don't think it is pinking (knock), maybe the compensator? The fuel octane spec in the Morgan handbook states 95/98 and the S&S manual says 91 or higher, even assuming that is AKI rather than RON that equates to 95RON and most fuel in Europe is 95 to 99 RON. The fuel octane shouldn't be a problem. Also there is a knock sensor on the back of the LH cylinder head that should prevent knocking via the ECU. If the high octane fuel and booster really does work though I will be happy to give it a go.
It might be a problem just here in the US. Our high octane at the pump is listed as a minimum of 91 octane. (It actually be higher but no way to tell)
I have used an octane booster from AMSOIL with very good results in reducing engine knock at and above 3500rpm.
Until I had the new ignition map installed to keep the pinking down I ran on Tesco Motillium 99 and Millers CVL.
Now with the new map, the pinking has gone but so has the performance.
I used to easily keep up with my mates DB9 to 80 but now I can't get anywhere near it.
At the moment I feel like it wouldn't pull the skin off a rice pudding!
Jeez , how high are you guys revving ? Anything above 3K revs and I get the prod of death from my co pilot somestick
Nippy, Flak Jacket would protect from all but the strongest of prods, keep her lit!
Funny creatures, co pilots. When they were younger they never complained about a fast run in the car or on the bike. Now they have somehow transmuted into punch-in-the-kidneys speed controllers. They are more effective speed prevention than police speed traps.
my steering wheel, my world, my rules!!!
I may not be the only M3W owner with a speed limiter and Airbag then?
swmbo
