0 members (), 303 guests, and 43 robots.
John V6 69
DaveW 66
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,037
Captain Morgan, IRWIN
Page 4 of 4 1 2 3 4
^ Using the usb that came with it ... same results in all 3 cars.
Starting being a problem after warranty expired ...
thumbs cheers
2013 M3W # 793
'Mosquito'
It's ok, you don't have to use the Windows interface if you don't want to, just run the windows apps in coherence mode so they look and behave like OSX apps:
Windows App in OSX
Smile, it confuses them
IMHO to assist.
These SatNavs are now built down to a price in a cut-throat market. Some of the devices offer a built in battery to allow you to avoid using the socket for short journeys or out of the car. One of the things they scrimp on are the batteries they fit. Unless you observe the battery charging and storage instructions these small cells often become very short lived.
Make certain the socket is rated for this load as the old ones often are not and have a low amp fuse. It may be worth considering a dedicated cable run to a subtle location out of site if you are going to use it heavily. A new product that was released recently which can help resolve charging issues is http://www.practicalmeter.com which sits in line with the USB cable and tweaks the connections. It has doubled the charging speed on my iPad in many cases where using a non-Apple power source.
A typical TomTom Go 5" will take a standard load around 1.5a at 5v through the converter. In many cases look for a 12v car converter that is rated at iPad capacity (3amp 12v) http://www.ebay.co.uk/itm/3-1A-USB-IN-CA...=item2ecb2c8b20 or consider using a standalone battery unit like this (not specifically recommending this item, there are thousands.) 3000mAh would be my recommendation as a minimum.
http://www.ebay.co.uk/itm/12000mAh-Porta...=item1c3979dba1
I agree about using a retailer to review them however I would hesitate on recommending any part of the dixons stores group (Dixons, Currys, PCWorld) as they promote specific products that have a high margin. You may not get a clear view. Most offer the same range of capabilities and the spot price and comfort using the software interface tends to be a key decider once you have decided size and features.
Hope this helps.
thumbs cheers
If that is the case, then it looks like a new battery is required. Quite a simple job and doesn't take too long.
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
Page 4 of 4 1 2 3 4
