6 members (Alistair, Sir Percival, GrumpyPa, Morganmike, JMcL, Chris Cosher), 343 guests, and 19 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,842
Posts837,331
Christoph
Page 3 of 14 1 2 3 4 5 13 14
Originally Posted By Dab of oppo
Make friends with your local tester.
The choice of testing stations that can test a 3 wheeler are fairly limited, so this is the best advice. Every year that I took my other 3 wheelers to get tested the "testing" got less as they get to know the vehicle and the standard you maintain it to, hopefully that will be high! The brake rollers were a nightmare and only tried by the most determined tester.
Sorry gents, life get in the way with kids and wife and kitchen remodel etc, etc, etc. I'll report back JUST AS SOON as I get a moment of free time.
2000 G500, UNIMOG 1550L37 DoKa, M3W
you "remodel" your wife???...what kind of "kit" and where did you get it?
That could be quite a large group buy innocent
The M3W will need a 3 wheeler MOT station!
As said these are getting fewer and fewer - there is only one to my knowledge in S.Warks!
And I think u will need a cat as well!!
Having said that the few 3W MOTers are v well versed in their testing. This has been my experience anyway! cheers
Neil
I'll repeat myself
In the UK, because of the weight, you need a class 4 (car) MOT. But because a tray or similar is needed to support the back wheel on the ramps, the likelihood is only testing stations that do both class 3 (lightweight three wheeler) and class 4 MOTs will be able to test a five speed three wheeler.
Brake rollers only work on a pair of wheels, so although the fronts are testable this way, the back isn't. However, the brake can be checked to see if it basically works when the car is on the ramps, and a Tapley gauge and road test will satisfy the rest.
I assume the on-line records with the DVLA are correctly set up, but I think unless you are too far away, arranging the test through the dealer would be the best start.
Added - a working cat is needed in the UK for a class 4 MOT.
Thanks Martyn - factual and helpful - as always!!:)) cheers
Neil
In my humble opinion, this has turned out to be a successful modification. Just the right amount of a additional noise and horses. I wish I had a before and after dyno test to see the real numbers, but I will say there is no loss of torque or power anywhere, I can feel, in the power band. The sound could be a little bit louder still, but there is a definite improvement in that department as well.
Bottom line, if you don't need a smog test, go run and tear those things out!
huzzah! this is so exciting as i've been wanting more meat to the exhaust not but really not wanting to reinvent the wheel and get a custom exhaust made. any chance you could do a short video of the trike with the engine on and maybe a rev or two?
PM me if you need a place to host the video and i'll get it posted for you
b
blake
sfmorgan.tumblr.com
did you have to do any welding after it was done or can you just reclamp the exhaust back on?
Not sure why there are Cats on the M3W in the first place, other than US spec models needing to meet The Republic of California's regulations for import, so I'm taking the plunge and removing mine. Fairly quick job with a rubber mallet and a long flat screw driver. I drove the screw driver blade all around the outer edge of the honeycomb material until if felt loose within the chamber. From there, it is a simple, but slightly tedious job of fishing the honey comb plug out. A few more minutes of scraping the inside wall free of left over bits, and bobs your uncle.
I'm at work today, so I'll have to report back tomorrow how it sounds and feels back on the car. I'm hoping for a gain of a more horses and at least a few decibels. Fingers crossed
blake
sfmorgan.tumblr.com
