8 members (RJW, Hamwich, OZ 4/4, xc68anc, IcePack, Mike D, 42w203, RichardV6), 366 guests, and 41 robots.
+8Rich 69
Adam12 69
John V6 52
9,215 Registered Users
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,375
Posts813,544
Members9,215
Page 4 of 6 1 2 3 4 5 6
At the risk of stating the obvious to those with greater skills than I have in these matters (ie quite a lot of people on here), the technique when drilling into fragile materials such as tiles, glass or, as in this case, painted metal, is as follows:
1) Cover the target area with masking tape.
2) Carefully mark the drilling point with a pencil.
3) Start with a smaller drill bit than the hole you will finally make.
4) Set the drill to its lowest speed (and check that the hammer option is off!).
5) Proceed carefully.
6) Enlarge hole to final size.
7) Remove masking tape.
8) Finish job.
9) Have a glass of Aberlour.
Thanks Peter, I will now know how to do it properly when fitting my 2nd Brooklands screen, I think the first one was more luck than judgement! After that I'll think about fitting those two sprung clips to the front of the cowl, they look so neat on your car, that I'm committed to thinking about them.
I was considering just aralditing them on .... then doing something more permanant once the new fasteners were proved ok after a few weeks etc
Aberlour whisky is for Tinkers!
Like all the previous steps.
Brora, Clynelish, Octomore, Ardbeg need I go on?
Ah, well, I'm a Tinker and you're a Pikey. For me it's Aberlour, Balvenie and Glenfarclas, though they sound like a dodgy firm of estate agents. Oh and Knockando.
If I want a smoky flavour, I buy kippers.
I have just reread my post here and its sounds all wrong - I dont mean to araldite the bonnet clips on ( how bad would that be ! )
I mean the roundheaded unslotted stainless bolts. Cut the heads off and stick them on over the leftover Dzus holes as a quick fix. Even then , if happy with the job I would probably get rid of the Dzus fastener completely and take the bolts straight through and retain on the inside - at this stage why not ?
Q
Q
Really the easiest & fastest way to install the bonnet...great solution guys
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zps9fb800ca.jpg.html][/url]][/url]
Nice one Q8.
I have recently sent off for a set of chrome latches as described in previous posts, apart from they look great I fancy the challenge of fitting them. Confidence builder for fitting aero screens.
Based on the various ideas in this thread I used a slightly different variation on mine....I use a small compression spring to hold the fixing outboard, retaining the plastic washer between spring and outside of the bonnet and I stop it coming adrift using a rubber grommet cut in half on the inside of the bonnet. Took minutes to do and all that's needed is 4 small compression springs and 2 suitable rubber grommets cut in half. Bonnet fit is now pretty straightforward, all 4 fixings are held out to just the right amount by the compression springs, the snug fitting half grommet allowing the fixing to come almost right out without coming adrift.. Works for me.
I've attached a couple of photos which hopefully explain
Good idea
