Topics49,842
Posts837,331
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
The question was academic, for now. But I wanted to be 'prepared' for two reasons. If it happened to you, it will likely happen to me as well and I like to understand and learn those kind of things. Really thanks again for your availability and support.
Posts: 262 |
No probs. Glad I'm able to help in some small way!
Posts: 262 |
It could be, or it might be the 'memory' function for the window closure system which operates independently on the driver's and passenger's side. My '09 Max seems to 'forget' the setting on one side or the other if I have not used it for a while - even if left on trickle charge.
Dean Royal has posted on here before about the re-set sequence. I found a guide from a BMW web forum which had the same info, but I have this at my other house. From memory it goes something like this.
Use window switch to put window fully open and HOLD DOWN switch for 5 secs+ (to unset) With door shut, close window which will auto-stop against seal and without releasing HOLD DOWN switch for further 5+ secs (to re-set)
Hopefully this will work (or call a friendly BMW dealer - it is their system MMC use)
Good luck Tried this procedure out several times by following your directives to the letter; but it didn't work.  The window still didn't lower when I tried to open the passenger side door... What am I missing?
Gone to Porsche Part of the Furniture
Posts: 4,333 |
have you attempted TWOTRIBES advisory but working with a 10+ seconds sequence ?
Posts: 318 |
Sitting inside,doors closed,engine running and than perform the reset sequence. Does it for me.
Rudolf
Morgan Aero8 S4 «Tango» Fisker Ocean Harley Davidson Livewire BMW R100/7 , R100R Moto Guzzi 254
Posts: 262 |
have you attempted TWOTRIBES advisory but working with a 10+ seconds sequence ? Yes I did - several times! But no joy.
Posts: 262 |
Rudolf That's probably why it didn't work when I tried it: I had the ignition switch set to "ON" but had not started the engine!!  I'll give it another go and see... Thnx for the tip!
Posts: 262 |
As it turned out, it wasn't anything to do with re-setting the window mechanism. A sticking micro switch was the main culprit and was duly dealt with! Job done!
Happy you sorted it out. At least I see that mine was not the only one with the lazy switch :-)
Did you get the switch cleaned or replaced?
Posts: 262 |
Did you get the switch cleaned or replaced? I brought it to an auto electrician and he put in a new one. They are cheap enough; but it's the inconvenience caused.  Now the passenger window works as it should...
