Morgan Aero 8
4 members (RichardV6, BLUE+4, TBM, Bilymog), 313 guests, and 33 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,842
Posts837,332
Christoph
Page 3 of 4 1 2 3 4
The question was academic, for now. But I wanted to be 'prepared' for two reasons. If it happened to you, it will likely happen to me as well and I like to understand and learn those kind of things.
Really thanks again for your availability and support.
Mad Max Offline OP
No probs. Glad I'm able to help in some small way! wine
Mad Max Offline OP
Originally Posted By twotribes
It could be, or it might be the 'memory' function for the window closure system which operates independently on the driver's and passenger's side. My '09 Max seems to 'forget' the setting on one side or the other if I have not used it for a while - even if left on trickle charge.
Dean Royal has posted on here before about the re-set sequence. I found a guide from a BMW web forum which had the same info, but I have this at my other house. From memory it goes something like this.
Use window switch to put window fully open and HOLD DOWN switch for 5 secs+ (to unset)
With door shut, close window which will auto-stop against seal and without releasing HOLD DOWN switch for further 5+ secs (to re-set)
Hopefully this will work (or call a friendly BMW dealer - it is their system MMC use)
Good luck
Tried this procedure out several times by following your directives to the letter; but it didn't work. frown The window still didn't lower when I tried to open the passenger side door... What am I missing?
Gone to Porsche
Gone to Porsche
have you attempted TWOTRIBES advisory but working with a 10+ seconds sequence ?
Sitting inside,doors closed,engine running and than perform the reset sequence.
Does it for me.
Rudolf
Morgan Aero8 S4 «Tango»
Fisker Ocean
Harley Davidson Livewire
BMW R100/7 , R100R
Moto Guzzi 254
Mad Max Offline OP
Yes I did - several times! But no joy. frown
Mad Max Offline OP
Does it for me.
Rudolf
That's probably why it didn't work when I tried it: I had the ignition switch set to "ON" but had not started the engine!! eek
I'll give it another go and see...
Thnx for the tip! smile
Mad Max Offline OP
As it turned out, it wasn't anything to do with re-setting the window mechanism. A sticking micro switch was the main culprit and was duly dealt with!
Job done! smile
Happy you sorted it out.
At least I see that mine was not the only one with the lazy switch :-)
Did you get the switch cleaned or replaced?
Mad Max Offline OP
I brought it to an auto electrician and he put in a new one. They are cheap enough; but it's the inconvenience caused. smile Now the passenger window works as it should...
cheers
Page 3 of 4 1 2 3 4
