2 members (paulgolfcar, +8Rich), 353 guests, and 62 robots.
Topics49,860
Posts837,486
Jonny72
Page 2 of 8 1 2 3 4 5 6 7 8
Hi Guys. I have been looking at the same project and replacing the current cover with the RSD Venturi 5 blade, contrast cut unit. I emailed M Rutter who replied he was not sure where the covers came from (?) but what i think is important to remember is the RSD assume their units are been fitted to an engine which redirect crankcase breathing fumes and the backing plates that come with the unit incoporate this to direct back into the carburettor. In my email to MR I asked if the backing plate was secured to the cylinders but I got no response. As far as I can see from trade pictures I think the MR fitted filter is simply mounted onto the throat of the carb with no cylinder support via the backing plate! If this is the case then it's not a good idea, as all that weight would be hanging on the carb throat! The carb screw mounting on our engines is 12-4-8 O'clock and I believe is the same as on the S&S E/G so if this option of fitment for the RSD unit is chosen we could be in a good starting place. An email to S&S resulted in a stern reply that the filting of the RSD would invalidate the Morgan warranty.....no surprise there! I was also told that the quoted £395 was plus duty too by the way. I am still in comms with S&S, RSD and couple of custom shops in the uk. Will keep you posted if I get anymore sensible replies from the suppliers.
After further investigation, it looks like the Melvyn Rutter version is from Kuryakyn and known as the M2.
Crowbar Offline OP
Agree that the RSD looks a tad nicer than the Kuryakyn - I also like the contrast cut / or even flat black...but I still like the S&S Muscle the best.
1965 Plus 4
2008 997 Turbo Cab
1981 Alfa Spider
1954 Austin Healey 100 (SOLD)
2013 M3W (SOLD)
Crowbar,
I put an S&S on my car at Brighton. We drilled 3 holes to orient the unit and it was done. Photo attached. By the way, this was the car you drove at Brighton.
Rick
Rick
'98 Plus 8
'05 Aero 8
'13 3 Wheeler
not a huge fan of the air cover replacement, but I do love the headlamp covers and your steering wheel.
Hi Rick, your 3w is really beautiful... and he has really nice neigbours in your garage ;-
www.facebook.com/mogpilot
With these open mesh aircleaner covers, do they not get a ramair effect, which would weaken the mixture? Or maybe the question hasn't been raised?
Normally, the installation of an air cleaner kit and performance mufflers will not cause any tuning problems for stock closed loop fuel injection systems, as they can easily accommodate the additional fuel requirements. The addition of performance cams will require additional tuning for proper operation.
It's from:
http://www.starracing.com/documents/2007-UpSellSheet2009.pdf
Crowbar Offline OP
BRAVO Rick - very nice - I like the two toned look.
That looks like the Kuryakyn filter...not the S&S filter...no?
I'm having Shane put the headlight covers on mine when it arrives as well!
Still trying to decide on stripes myself...I thought matte black on the metallic black I ordered might look good. I may try them in vinyl first...
Cheers!
Greg
1965 Plus 4
2008 997 Turbo Cab
1981 Alfa Spider
2013 M3W (SOLD)
Hi Everybody
This is mine with RSD Filter. If you need the adapter, let me know.
SuperDry Morgan ThreeWheeler with RSD Airfilter
Cheers
Patrick
