6 members (nestor59310, Barkingdog, IcePack, DaveW, DCH, mph), 300 guests, and 39 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,357
Christoph
Page 4 of 39 1 2 3 4 5 6 38 39
Originally Posted By donaldosaurus
I am pleased I did my £18 modification too.
yes, easy job and not expensiv at all!
I'll be doing the mudguard mod soon.
Can it all be done from the top or do you need to get underneath?
Red Leader drive
it can be done from the top. but its a lot easyer if you got a lift! that and how good equiped your shop is. so i did it with the morgan mechanic at theyr shop. i am a trained blacksmith and metalworker, but at home i do not have all the tools and machines.
Hmm - I'd be doing it on a sloping driveway outdoors.
Maybe I'll have a word with my dealer and see if they could help out.
Red Leader drive
Chris, do it yourself, it's really easy, and you will get satisfaction from doing a good job.
BTW, I used a rear bracket screwed to the wooden frame, it's easier and simpler.
chris, do not get me wrong! paulj is right. the reason i did it at the dealers shop was, because i had to do several modifications. in exemple the comfort steering thing, i could not do it at home by my self. the mudguard job can be done at home, of course. takes a little bit longer, but its simple to do.
Perhaps this should be a factory mounted option?
Chris
Assuming you are using the alloy deflector mounting at the front you will need access underneath to refit the two bolts. I raised the rear with a wooden block ramp only about 100mm but higher would be better.
Tim.
HJP Offline
I managed to fit mine with the alloy deflector mounting bolts without lifting it .
Hugh
I did mine without a lift , just had to lay flat on the floor at times to fit the factory mudguard bolts back on. All the rest from above.
