Morgan Aero 8
0 members (), 215 guests, and 38 robots.
+8Rich 91
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,335
Christoph
Page 3 of 4 1 2 3 4
Formerly known as Aldermog
Originally Posted By twotribes
Originally Posted By Aldermog
Seriously, if the battery goes flat after less than 3 months then Morgan has not specified the correct battery to go with the BMW electronics.
It's a little more complex than that Peter. Because of the way Morgan has adapted the BMW CAN bus electronic control systems for the Aeros, there are some circuits which stay 'live' even when the ignition is off. These will place a residual drain on the battery. (Max owners will be aware of the always-on rear glass release light for example).
I thought there must be more to it. Always on circuits are not exactly helpful. The trials and tribulations of software controlled cars....
I'll just go and polish my grease gun!
Take the bulb out?
Ale_72 Offline OP
Originally Posted By deano
It's a 2T aluminium trolly jack from UK supplier Machine Mart. They have a good website, take a look. I am sure other suppliers also sell similar.
Thanks Deano.
Is yours red or blue?
http://www.machinemart.co.uk/shop/produc...C-trolly%20jack
http://www.machinemart.co.uk/shop/product/details/020115155?da=1&TC=SRC-trolly%20jack
I bought this one a couple of years ago. Not from this site and significantly cheaper. Costco have them occasionally.
http://www.motorsport-tools.com/arcan-ra...ium-18-ton.html
Ale_72 Offline OP
Is that low and long enough for an Aero model?
Thanks Deano.
mine is neither of these. just had a look and its a Clarke CTJ2000A £179.98
Martin (Deano)
Ale_72 Offline OP
Great, thanks.
Dimensions (LWH) 630x300x240mm
With these it will be easy to find something similar in my areas.
http://www.machinemart.co.uk/shop/product/details/clarke-ctj2000a-2-tonne-aluminium-trolley-jack
My guess it's imported from China as is much of Machine Mart's kit, so if you do an Internet search I am sure you will find something similar. Or you could email Machine Mart and ask if they will ship to you.
Martin (Deano)
There's another way around the low jack issue.
Before you raise it drive front wheels onto some timber planks. I in fact do this, in spite of jack being low, since it makes it easier to put the spreader plate in the correct position.
Cheers
Philip
1985 Plus 8 four seater
Malone F1000 - track car
Ale_72 Offline OP
Yes, this is what I was doing with my 911.
Page 3 of 4 1 2 3 4
