5 members (Ritchie B, DJC, Clipper, TBM, sewin), 155 guests, and 44 robots.
+8Rich 92
Topics49,838
Posts837,294
#178577 26/01/14 10:53 PM
tide Offline OP
For those who have changed out their air cleaner, I did the swap today but noticed two holes on the top of the assembly that get connected on Harley installations, but I seen nothing included to cap these holes off. What are people doing here?
tide Offline OP
Attached image for reference.
I'd think I trip to your local hardware store should muster up a couple threaded plugs that could be hit with some black paint.
2000 G500, UNIMOG 1550L37 DoKa, M3W
Q
Q
I used car carb vacuum caps..its all in the detail,looks factory.i also used wire cover on part of the throttle cable,where it rubs on the heat cover.
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zps9a4fb253.jpg.html][/url]][/url]
Smart.
tide Offline OP
I ended up epoxying the one end shut, since I wanted to go for a ride tonight. smile
I do not know if anyone has ever tried to set up a conical air filter directly, so I'll ssay by adding a sheet metal from Aluminium to cut fixed with the engine cylinder heads, if it is necessary I would add a spider aluminum into the before the air filter.
[URL=http://www.hostingpics.net/viewer.php?id=264700Photo0265.jpg]
[url=http://www.hostingpics.net/viewer.php?id=963143Photo0268.jpg][img]
http://crosscar.go-gti.com/filtres-green-filtres-green-universels-xsl-258_283_48_87_299.html
Mine...Sorry not a good photo
[/url]}
Could someone post the part number / url link for the adaptor to connect these air filters to our S&S engine please. I am assuming this is a stock adaptor which will suit a range of filters ?
I know very little about Harleys - will this adaptor work for any Harley replacement filter ( e.g. Kuryakyn ) or should I be looking out for a keyword or size to indicate compatibility ?
Thanks
