5 members (scortroadster, chanteclair, SteveT, DPEvans, JohnMat), 365 guests, and 132 robots.
Sagging Hood
Topics49,859
Posts837,479
Page 3 of 4 1 2 3 4
I forgot to mention I had a factory fitted Moto-Lita to start with, I do remember When I had a Lone 3.0 that I kept hitting my fingers on the dash and the leather already had scuff marks on it that was fitted with the standard S/W.
Note S/W is always fully up to keep of my legs. That is why on my Mog the plastic cowl is removed to get the extra room.
I have 15" S/W now it came with 14" but I didn't like it.
Cain
Wolf Cafe Racer
4/4 Sport
Cain has very kindly sent me some photos and a sketch. He suggested that I could post them on TM if I liked as he has trouble posting photos. So here they are with the explanatory part of his email.
Rough drawing (the attached pdf) not to scale my Moto-Lita steering boss already cut down to my size a further 20.70mm could be lost if the 3.5mm of the Mog steering shaft is removed. A further 12.5mm by removing Lifeline spacer to steering wheel but this would require the horn to be moved to the dash. But you would need to check if this interferes with your Dash.
I think I would go for something like this http://www.demon-tweeks.co.uk/motorsport...ring-wheel-boss
that does not have splines, and weld on. I believe the Mog steering shaft is from a Land Rover discovery but not 100% I would not wreck my Mog one unless I had a spare.
more photos to come
My dash measurement
Measured from Dash
Measured from Column stalk pod with cowl removed
Bullet connector in rubber hose to contact Moto-lita push Horn
More of Cain's photos
Spacers x2 Lifeline 12.50mm and Moto-Lita 3.66mm (silver) needed for horn
Horn RHS with male electric connector to contact bullet connector when horn pushed
Interesting stuff Cain. Thanks for posting Peter.
Incidently I found out why Cain had trouble posting his photos. It seems his camera saves them with the extension .jpeg which is not accepted by the forum software. It is simply a matter of changing the file name extension to .jpg
The file extensions are not normally visible and it is necessary to make them visible.
The german Morgan dealer Morganpark offers also a steering wheel which is 14" at top with a 13" lower park. They are a bit thicker than the Moto Lita wheels.
Morganpark steering wheels
Keep mogging,
Christian
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
You may have solved a bigger mystery. Should be highlighted elsewhere?
I was too busy looking at the compass and rally clock... grin2
Keep mogging,
Christian
The Morgan Park steering wheels look pretty good and you must look twice to see the imbalance.
Ok Graham just for you my first PHOTO 'The Rally Cockpit' I hope and thank you Peter for you help
[img:center]http://www.flickr.com/photos/116051653@N07/[/img]
Cain
Wolf Cafe Racer
4/4 Sport
Page 3 of 4 1 2 3 4
