6 members (Doug J, Graham, G4FUJ, Guten, Peterkul, Image, Soleng), 204 guests, and 55 robots.
+8Rich 91
Topics49,841
Posts837,316
Page 3 of 17 1 2 3 4 5 16 17
Toys for Boys
Toys for Boys
From Aero Racing (Thanks, Mark Evans)
M3W Suplex kit has been developed for front and rear on adjustable platform suspension retail price £1310.21 + vat
I’ve attached a file with more info on the M3W kit for your information.
Omne trium perfectum
A good example of enthusiasm, dedication, and professionalism working together to produce an innovative and highly functional solution.
Well done Suplex and Aero Racing.
HJP Offline OP
It does sound good , my first step is to get the comfort kit fitted (been waiting 3 wks now ) and see how the car feels .
Then the question is , how much do I keep spending , whether to do more work on the suspension , and/or perhaps bite the bullet and get the improved compensator and bevel box mod ?
Or do I wait and see if a new 'sport' version comes out with all the goodies and perhaps an upgraded engine ?
Hugh
Very expensive !
Are they dreamer ? Or crazy...
PJB Offline
Neither - a great engineered solution, perhaps this is how it should/could have been from the start. This ultimate upgrade is produced because of the great demand for it - the Morgan factory test drivers love it! Try one and you will see how a sports three wheeler really should ride and handle!
You get 4 off monotube dampers, all gas pressurised, all with bump & rebound damping adjustment, rising rate springs, internal rebound springs etc. Cheers PJB
Interesting and thanks for sharing....shame they have a typo in their email address - might sell more if it was correct. smile
Quick question, what is the spring rate on most of the front coilovers?
Thanks.
Dan
Toys for Boys
Toys for Boys
PBJ - Non technical question, but relevant for the look of the car - are they painted all black like the factory fit shocks?
PJB Offline
BlackAdder, the damper body is black with red spring seats and red adjuster knob. The spring is 'silver' powder coated. Regards PJB.
PJB Offline
Dan, not sure I understand the use of the word 'most' in your question, but: of course the spring rate of all the SUPLEX units is proprietary information, however typically the initial spring rate is softer than standard for good ride then goes a lot stiffer than standard in bump and roll to minimise full bump impacts and increase roll resistance. The internal rebound spring stiffness is very stiff in comparison and also progressive. Gas pressure also adds some stiffness and is proprietary info too.
To set spring rate if you intend to do your own; determine what bounce frequency you want and then measure mass of front end and do the maths. The rate progression is essential if you are to run softer main springs in any application.
The progressive non-uniformly wound rear springs & rebound springs are more expensive to make as they need a special spring winding machine to form them and the elastomeric front 'spring assist' (Durable closed cell high density elastomer) are unique to this product I believe.
I hope this helps a little. Regards PJB.
