10 members (nick w, howard, RichardV6, Grumpy2, Jensen1960, Rex_tulips, Gerry Seale, IcePack, +8Rich, Mauli),
266
Topics48,362
Posts813,328
Members9,215
Posts: 6,538 |
Have just ordered a 280mm sender from Eurospares -very helpful:) will post again about this when fitted - sounds/looks like an easy fix:))
Neil
Posts: 19 |
I installed the new 280mm unit from cip1 yesterday. Big improvement. Looking inside the tank when installing I guessed 50% full. Gauge read 46% when installed.
Went for long ride of about 50 miles and gauge seemed to go down in 1-2% increments which is a big improvement. Original gauge would have been reading close to 0.
Good modification.
BRGMog
Posts: 1,649 |
Are we now sure that 280mm is the way forward?
Posts: 1,959 Likes: 15
Posts: 1,959 Likes: 15 |
Why? It does fit and work.
Posts: 6,538 |
Fitted the 280mm sender - must be the easiest fix i have ever done on any car (or bike!) And works sooo much better as posted above!
Neil
Posts: 1,338 |
May you send a link or item name,part#
Posts: 695 Likes: 6
Toys for Boys Talk Morgan Regular
Posts: 695 Likes: 6 |
Omne trium perfectum
Posts: 1,338 |
Thank you,just ordered it.
Posts: 695 Likes: 6
Q8 - when you fit it be very careful threading and tightening the bolts as it is very easy to strip the threads in the tank. One of my bolts had been over tightened by the factory and was spinning.
Posts: 1,338 |
Oh ok,thank you,ill keep that in mind
