Topics49,843
Posts837,335
Posts: 1,338 |
Great point about the electronic memory loss.will it happen if we disconnect the battery? how can we update the ecu if needed at home?
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
I disconnect the battery regularly as I've not got power in the garage for a battery conditioner.
On reconnection it's fine, no loss of trip or mileage data but the clock does need to be reset.
Red Leader
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
The fuel sender circuit is not powered when the ignition is off. There fore, I did not disconnect the battery.
Roland
Posts: 6,538 |
Recommend Eurospares too - v good service:)
No need to disconnect battery - but take precautions - ignition off - and disconnect positive first /connect neg/earth first when fitting etc - usual good practice stuff:))
Neil
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Did you mean Europaspares rather than Eurospares? Two very different companies.
Posts: 1,461 |
No need to disconnect battery - but take precautions - ignition off - and disconnect positive first /connect neg/earth first when fitting etc - usual good practice stuff:)) Er, no. Negative/earth should be disconnected first.
Posts: 6,538 |
Yes Europaspares!sorry:(( Yes Neg/earth disconnected first - oops - had a bad day!!
Neil
Posts: 1,461 |
Well, it could have been a far worse day if you had followed your own advice!
Posts: 6,538 |
Neil
Posts: 1,338 |
Just arrived fun installation time [url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zpsab555e3b.jpg.html]  [/url]][/url]
